I'm re-listing this after a previous sale. Sadly after a tussle with DPD on sending this out the Hypex unit failed. It has been returned to Hypex, serviced and is in full working order. As a result of the last experience I am listing this for collection. You are quite welcome to arrange your own courier to pick up but you will be responsible if anything is to happen to the items.
I am also leaving the units as they are. I won't be fitting the new unit but if you can use an allen key and a cross head screwdriver it's very simple. I've included photos of the case and the Hypex amp and also previous photos of the unit fitted. I will also be including a power cable and a custom DIN to XLR lead designed for Naim pre amps.
FEATURES:
Two channel amplifier
5W standby SMPS
Advanced over current protection
External controlled operation
Auto-switching (115/230V)
Low weight: 1055g.
Compact: 230x115x47mm
HIGHLIGHTS:
High efficiency
Universal mains operation
Flat, fully load-independent frequency response
Low output impedance
Very low, frequency-independent THD
Very low noise
Specs
Technique NCore
Power (2Ω) 2X 450W (not advised to use in BTL)
Power (4Ω) 2x 500W (1x 1000W in BTL)
Power (8Ω) 2x 350W (1x 1200W in BTL)
Channels 2
Weight 1055g
Dimensions mm 230*115*47
Mains voltage input 230V / 115V
Automatic input voltage selection Yes
Collection: Oxfordshire
Price £650 reasonable offers considered
