Would I hear an audible improvement if I used a 4 mm speaker cable, compared to a 2.5 mm one?
Using between 1 and 3 metre runs.
Thanks!
Thanks!
Bluesound Node 2i
Audio Analogue Pucinni SE
B&W DM607 s2
Klotz ic’s
I'm Dennis.
In about '02 I went through several speaker cables, and ended up with Kimber 4TC and later 8TC. The latter, fatter, weirdly altered the sound, it losing clarity and top, and making the bass boosted and boomy. This was an anomalous effect IMO, and was costing hundreds of pounds.
Now I just use a good 2.5mm cable, and this is for 3m pairs.
Ive always gone with big fat cables as things seem to improve when I listen to large cross sectional areas. Current cables have 10mm2 cross sectional area.
To clarify, same brand and model of cable
Bluesound Node 2i
B&W DM607 s2
Klotz ic’s
i guess you're using Van Damme? If so, do try the terminated 6mm variant. Absolutely superb.
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
In principle, I would agree with most that cables shouldn't make any (or much) difference. However, in my experience they can and do make a difference on occasions, sometimes possibly due to the synergy involved with the rest of your system.
From experience, I would offer that upgrading invariably does little in the way of perceivable change and after a few days / weeks, you will be comfortable with the sound you are listening to. However, if you then substitute your previous cables back into the system the sound will be easily identified as inferior if the upgraded cables have achieved anything. Interestingly, I don't believe that SIZE actually matters.... just look at Audience / Mogami which are not only tiny in cross section, but also coaxial!
If possible try an upgrade set of cables and see how they sound, but don't reintroduce your old cables for a few days or a week. If then, you don't detect any difference when you revert the system to your old cable you have answered your own question.
Technics SL1000R, DynavectorXV1t, Garrard 401, Jelco SA750LB, Decca Reference, ATVM750SH, AT33Mono, Hana Umami Red, Reimyo CDP777, EarYoshino 912, Ear Yoshino 509s, JBLK2 SL5800s, ART Dram interconnects / speaker cables.
I'm Jo.
Essentially the claim from some manufaturers is that '...by using a thicker cable, you increase the dynamic range, and add (sic) detail and resolution to the sound you are carrying...'. I'm not sure my experience underwrites that assertion. Why stop at 4 mm or 6mm, when 12mm or 24mm will 'add' more to the dynamic range and to the detail and to the resolution?
