Audio Note (UK) M6 RIAA phono stage in utterly mint condition and with original packaging. It is approximately five years old, and believed to still be current specification/circuit topology with dual mono power supplies, GE 5670s in the equalisation stage, and a NoS Tung Sol 5687 for the gain stage. Resistors are AN Tants, power supply caps are AN Kaisei, signal caps are AN copper foil, and the signal wiring and windings on the outputs transfomers is silver. Spare set of NoS cascode tubes included. Moving magnet input only: to use it with a MC or low output MI cartridge you’ll need a step up transformer. Input is 47 K Ohms, output impedance is less than 10 Ohms. It can be operated in full balanced mode, or single-ended.
£5,150 plus carriage at cost.
