Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Tips on removing screws stuck in metal plating.
    Default Tips on removing screws stuck in metal plating.
    Putting new flooring in my luton van, and the screws to keep the plywood down go straight into metal plate, some of them - many of them! Will not budge, even with wd40, any tips, this needs to be done asap or I have no floor!
    Drill them out and replace with like?
    PRE
    As you're putting new flooring down I guess it doesn't matter what happens to the old, so just chisel out around the stuck screw heads to make room and use hefty mole grips to undo them.
    grind them off flush if worst happens. thats once you get the wood up.. you might be able to cold chisel them off wood or as geoff says mole grips might shift them too.
    ive done it befor so it will come off,, but can be messy
    other option is just to put new wood over old wood.. done that too
    I'm Alex.
    Perhaps angle grind a new slot in the head of the screw, use a big screwdriver!
    Spendorman
    I'm Gary.
    Impact driver?
    Gary
    I'm Edward.
    Impact driver?
    Gary
    That's what I was using, still couldn't shift some of them! Easier once the ply was off though.
    Thanks Gents, all the ply is up, as someone said chisel around it, not too hard. Still about 20 screws stuck, in metal plate, should come off fairly easy now ply is up.
