Results 1 to 8 of 8
Thread: kt88 valves
    I'm jamie.
    Default kt88 valves
    has anyone bought valves from them? they make some bold claims and would appear to be a better choice than chinese ones.
    https://sophiaelectric.com/collectio.../pages-se-kt88
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon KB with vienna upgrade
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    KARMA Interconnects & Tonearm Cable
    I'm AnDreW.
    I've heard about them and seen a few reviews. They are expensive, I'm happy with my GEC KT88 CLONES, if the form of the Genelex gold lion KT88.
    CD Teac VRDS25X(Audiotuned) DAC Caiman SEG+15V PSU+Dorado DECK 1210 Mat Crystal Audio Mods MN Base/Bearing/Platter+Ebony armboard Feet Isonoe/Ebony PSU Paul Hynes SR7EHD-27XL/DCSXL Ag DC lead/3 Stage Regs/Recap PCB+No Pitch/Strobe/Light ARM SME V(Kondo Ag Rewire&Tags) MC Cadenza Black FGS CABLES Arm Yannis SPD-4 IC Yannis 222 Litz+Ag bullets Power WAR PRE ATC SCA2 SPEAKERS ATC 50ASL STANDS Atacama PHONO Sugden Masterclass PA4 SUT Ortofon ST80SE POWER PSAudio P10
    PRE
    Croft Epoch(Modified) AMP Sondex S100 (Modified) SPEAKERS Tannoy 15"MG+RFC Warwick cabs+ Reference XO DECKS Garrard301/401 (Bastin) Mat Teunto Bearings 301/401(Bastin) Plinth Moldovan/Bastin Arms 3009/3012(Ikeda Ag wired) SME V 12 PSU Eagle+Tachometer MC Ag Meister v2 / Royall N SPU's CABLES Arm Yannis 420.5 Litz+ Speaker 10mm Cu + WBT-0681 Ag IC Oyaide FTVS-510 AgWBT 0110Ag Phonostage Paradise(4 Box Modded) / EAR 834 Clone (modded)
    REAL SOUND
    PRE Radford SC25 (Mullard ECC83/82) POWER RADFORD STA25 Renaissance (Electroharmonix EL34) SPEAKERS Celestion Ditton 15 (Duelund Rewired/Jantzen+Duelund Recapped) CABLES Speaker - Duelund AWG 12IC - Belden 8402+Switchcraft RCA
    I'm Justin.
    Quote Originally Posted by karma67 View Post
    They are Chinese.
    Sophia rebrand Chinese valves. They don't make them.
    Utter bollocks. Made in China and rebranded. If you like the look of them fill yer boots. I'm betting that the Genelex mentioned above will be just as good or better. I remember Bill Beard once telling me over a beer or three about his trip to the factory in china where he bought a consignment of KT88's. He told be they stopped the production line where Gold Dragon's were being made and the screen print changed to Beard. There is a lot of Billy bulsh spread about valve rolling. I have just re-valved my amps with stock Chinese valves and they sounded just as good as the expensive ones i had replaced the originals with.
    I'm jamie.
    I’ll stick with my gec’s I think!
    My System
    John Wood KT88 Amp.
    I'm Justin.
    I one bought 12 Golden Dragon EL84s for my Bill Beard BB100.
    3 months later half of them had failed.
    Sophia rebrand Chinese valves. Fact.
    So why utter bollox when it is a fact?
    A lot depends on the valves in question and the circuit they're used in [i.e. how hard they're biased/driven], as to whether or not current production Chinese valves will be as good as something more expensive, or NOS. Almost invariably though, IME, the *best* NOS valves (in closely matched pairs), of any description from the best traditional manufacturers, will outperform Chinese varieties, simply because they're much better made.
    I've had considerable experience of using KT88s (in various amps), and for me, the best sounding (and most reliable) ones by a country mile are in the following order:
    1) Original GECs - but at now crazy cost!
    2) E.A.Ts: https://www.europeanaudioteam.com/en...-wp000023.html
    3) 'Winged C' Svetlanas (now unfortunately discontinued).
    4) Golden Lions.
    TBH, I wouldn't grace a good KT-88-based amp with anything else, especially the 'all fur and no knickers' poncy shit, shown at the beginning of this thread, as they're designed to appeal to a certain type of buyer (one who judges more on looks than anything else) and simply aren't built well enough to be reliable!
    Therefore, IMO, they're to be avoided at all costs, as they're a total waste of money. So, sorry, Jamie, it's a 'no' from me
    Tape Deck: Tandberg TCD 310, fully restored and recalibrated as new, by RDE, plus upgraded with heads from a TCD-420.
    Tube Distinctions digital noise filter. VPI HW18.5 record cleaning machine.
    Oh, and one further thing... If the KT-88 amp in question can be made suitable for use with KT-120 (or 150) valves instead, then that'll likely be the best sounding option of all - and much cheaper, too!
