Results 11 to 20 of 39
Thread: Speaker dilemma
    Is there not a 2 ohm also?
    I can't find any measurements for the speakers but the quoted low bass response is 38Hz - no indication of what level that is at though. I wouldn't expect a decent size floor stander with twin 7 inch bass drivers to be bass-light in any room. I wouldn't rule out the amplifiers not being up to it if I were you.
    They do have a 2 ohm tap yes. I will of course try it on your recommendation. However, it is worth noting that they sounds the same with my very old MF A300 which is no slouch.
    This post should not exist then?
    Have a look at how they coupled to the floor. If they are on spikes, you could be losing a lot of bass into the wooden floor.
    They are on spikes yes. I will take them out and try them without.
    I'm Kevin.
    Seems it could be the speakers - https://www.soundstagehifi.com/index...tmpl=component
    https://www.sonusfaber.com/wp-conten...iew_112015.pdf
    Although, based on the specs, I think a small sub would certainly help.
    Kevin
    I'm Kevin.
    Quote Originally Posted by Floyddroid View Post
    Or put something solid under the spikes.
    Kevin
    I'm Kevin.
    The best frequency response chart I can find - https://www.sonusfaber.com/wp-conten...20T_082015.pdf
    Kevin
    I'm Adrian.
    I have a pair of Sonus Faber Chameleon floorstanding loudspeakers which sound very good up top and in the middle. However, they are quite lacking in the lower registers and wonder if i should look at replacing them or adding a sub. I use Prima Luna Prologue Six monoblock power amps and know that they are not lacking in any way. The Sonus Faber's are sensitive too soo they sould have absolutely no bother driving them. Your thoughts please.
    I would advise doing what I did to help with the carpet issue, go out and buy some 40mm solid oak kitchen worktop off cut, enough for two speaker platforms, and then to improve bass control get some go these, they will isolate the speaker from the wooden floor even more, yes I know they will be wobbly but it does work!
    https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
    or these
    I have tried various combinations and prefer the Hudsons.
    Also I would that you try this out to the letter, https://www.tnt-audio.com/casse/waspe.html
    Steve have a read of my thread it may help https://theartofsound.net/forum/show...ight=isolation
    I now have deep full controlled bass with a much better detailed soundstage. You can always experiment with different types of rubbers isolators like I did to see which one you prefer best. Jerry who used to be on here along with a few others has tried what I suggested and were quite shocked at the improvement.
    Worth a try and not expensive, before you go replacing speakers.
    Sounds like it could be the speakers then. But nothing to lose by trying the 2 ohm.
    Yes it would appear that the speakers are shite.
    I'm Kevin.
    For bass, yes.
    Kevin
    if you like everything else the speakers do, then it may well be worth trying a sub. Or two!
