Results 1 to 8 of 8
Thread: PCB Production
    I'm William.
    Default PCB Production
    Hi Guys
    I’m looking for a recommendation for someone who produces PCB.s I only need one so looking for reasonable cost.
    Thanks in advance for your help.
    All have a good day.
    Regards
    William
    I'm Alex.
    I use Eurocircuits, they accept files from Eagle and KiCad and plain Gerber files.
    Good quality as well.
    https://www.eurocircuits.com/
    I'm Jeremy.
    Do you need design work or just someone that prints?
    I'm William.
    Hi Folsom
    I just need someone to print it’s in a Gerber/ Excellon file format.
    Thanks
    William
    Quote Originally Posted by Pegwill View Post
    Hi Guys
    Regards
    William
    Hi William
    Easy EDA is highly recommended https://easyeda.com/
    It is complete, from designing your pcb with a very easy interface that takes you through schematic placement then board design , generating a gerber file, and ordering your pcb
    on a scale of the best, it gets 10/10
    Unlike other programs ( IMO clunky dreadful interfaces ) that insist on you using certain unhealthy proprietary software, ( Kicad although as a unburdened file - never the less is clunky and just hard work ) easy EDA
    in comparison runs in your internet browser, you can choose to keep your file private or indeed publish it if you are inclined.
    Hope that helps
    I'm Jeremy.
    Hi Folsom
    Thanks
    William
    JLC, Seeed, DirtyPCB are some go to for inexpensive. If you need the finest quality Imagineering is great.
    I'm Sandro.
    Endless options and not expensive and turn around is really quick
    I just had 10 U PCB made
    Yes that is not a tipo 10 U in cooper weight
    I'm William.
    Hi Guys
    Thanks for the replies. I will do some further investigation.
    Regards
    William
