Results 1 to 3 of 3
Thread: Need some advice please fm-300A
    I'm matthew.
    Default Need some advice please fm-300A
    does anybody know what to check the volts across when adjust the bios trim ?
    The 0.22 ohm resistors below the big power transistors.
    Adjust for around 10 millivolts (0.01V) across the resistor. Don't overdo it or you'll let the smoke out
    Would be interesting to see effect of a common drain mosfet implementation, maybe using gate feedback -instead of plain resistance.
