Results 1 to 10 of 11
Thread: Edwards Modulus 686 build
    Default Edwards Modulus 686 build
    Initial case parts 'look-see'.
    Feet fitted.
    Dry run case assembly with new layout 686 boards, plenty of space for ventilation.
    IEC inlet hole cut, not easy in 4mm panel.
    Remaining holes cut in rear panel and connectors fitted.
    More to follow..
    I'm Kevin.
    What case are you using Alan?
    I am keen to see how this one comes along, as I will be ordering my pre-drilled case at the weekend.
    Kevin
    I'm Edward.
    More progress today.
    Power wiring installed on control board:
    Speaker looms fitted and checked for size:
    Power supplies fully installed:
    Not long now.
    Amplifier boards mounted on drilled and tapped heatsinks:
    Finished assembly:
    Looking good Alan.
    I'm Edward.
    Let's hope that special magical smoke does not get released into the wild.
    I'm Ian.
    Very nice work Alan
    I finally received the correct sized text for the front panel, a bit of delay due to the holiday season.
    Firstly a picture showing the link in the XLR socket, to enable use of the single ended input, an idea pinched from Krell:
    The completely finished amplifier in all it's glory:
    These Neurochrome amplifiers (I have the 286) are stunning performers, I tell people they are end game amplifiers, IMO.
    The sheer transparency is almost magical, I certainly won't be looking for anything different.
    It can now (finally) make it's way down to Edward's new place.
    I'm BigBobJoylove.
    PM’d you O Fiery One.
