Results 1 to 7 of 7
Thread: A question about amplifier selector switches, valve amps and splitting sources.
    I'm Howard.
    Default A question about amplifier selector switches, valve amps and splitting sources.
    I have one source (a DAC), two amps (a Radford valve amp and a Rotel transistor amp) and two speakers (JR149s). I want to be able to switch between the amps easily (to save the valves)
    I think I could use this Beresford switch -- it looks suitable for the Radford even if I accidently turn it on with no speakers connected (but I'm not totally sure.)
    http://www.homehifi.co.uk/S/tc-7210.htm
    Could I get the source into the amps just by using a pair of splitter leads like these?
    https://www.amazon.co.uk/dp/B000LB29...nkfishmedia-21
    Yes the splitter box is okay and does say it provides a dummy load so no issue with the Radford.
    Yes, you can use Y splitters to run the source into two amps.
    I'm Howard.
    Thanks, and I think I’ve put this into the wrong part of the forum. Sorry.
    I wasn’t sure about the Y splitters. I am not using a preamp. The DAC outputs 2V. Will each prong of the Y get half of this?
    Quote Originally Posted by Mandryka View Post
    Not if one amp is switched off.
    Both amps will get the full output level. The Dac will have a low enough output impedance to drive both amps without problem.
    I'm Howard.
    Thanks gentlemen.
    I'm Edward.
    I use a Y splitter such as these.
    How are you controlling volume without a preamp? Via the DAC?
