Results 1 to 2 of 2
Thread: Neurochrome Modulus-86 Mono Blocks
    I'm Kevin.
    Default Neurochrome Modulus-86 Mono Blocks
    I have for sale a pair (2) of Neurochrome Modulus-86 monoblock amplifers.
    For all those who have speakers of at least 86dB sensitivity and looking for a neutral, but natural sounding amplifier, look no further.
    I bought these amplifiers earlier this year, ready built, and I am selling them to help fund my build of a bigger, more powerful version of this amplifier.
    Each monoblock consist of 160 VA (230V)transformer, made to the original builders specifications.
    Each power supply board consist of 4x10000 uF 50V Nichicon capacitors and dual rectifier fast recovery diodes. For wiring speaker lines, Jantzen solid core wire was used.
    For power indication, a 2 mm green LED is neatly recessed in the front panel.
    The mains switch, installed on the back panel of the amplifier is rated 15A.
    The XLR input connector are gold plated Neutrik sockets.
    Dimensions of each monoblock are: 22x27x7 cm (WxDXH).
    Both monoblock amplifiers are in perfect operating condition.
    They are rated at 40W into 8 ohms, and 70W into 4 ohms, with extremely low distortion levels.
    You can read a lot more information about this amplifier here, together with all measurements:https://neurochrome.com/products/modulus-86
    I am after €560 for the pair + postage.
    Please note, no power leads will be provided with the amplifiers.
    Kevin
    I'm Kevin.
    These are now sold.
    Kevin
