Originally Posted by
Lawrence001
I beg to differ but if you're not gelling with the valves in there, you risk still not enjoying the sound when you upgrade the phono stage valves as the line stage valve may still have the same issue.
If it were me I'd spend some time listening to the digital side and if you hear the edge that bothers you then sort that first.
Once it's gone from the line stage then do some listening to the TT. If the edge has gone, job done. If it's still there then you can start rolling the phono stage valves too.
If the edge is not there with the digital side in the first place, then move straight onto rolling the phono stage.
If you sort the phono stage out first you risk overcompensating for the harshness of the line valve, and if you then have to change that to get the digital side sorted then you risk having to make further changes to the phono stage to compensate.
Sent from my HRY-LX1 using Tapatalk
