Results 1 to 10 of 17
Thread: Suggestions for tube rolling Croft integrated anyone?
    I'm Joe.
    Default Suggestions for tube rolling Croft integrated anyone?
    Hi All,
    New member from New York.
    I just acquired a Croft integrated and I'm pairing it with the Harbeth P3XD's
    in a desktop setting.
    I set up this rig about a month ago,everything is new including the Mark Grant VD speaker cables,
    HDX1 interconnects and a Topping E30 Dac.
    I run Spotify and Itunes for casual sessions and listen critically with
    my AR TT and Sumikko MMT arm w/ Hana EH cart.
    I'm not in a big rush to swap out tubes because I want to
    really get accustomed to the sonic signature of the gear BUT
    I do get that itch to try my stash of tubes,especially on the phono stage.
    I have a matched pair of Raytheon 5751's/12ax7's of Genalex Gold Lions/Mullard CV4004's/IEC 1960's Mullards.
    and
    my single tubes include a JAN 1963 12ax7/GE 1980 12ax7/Re-Issue Mullard 12ax7/Tung-Sol 12ax7 as well as a single Mullard CV4004
    & a Fisher West German 12ax7
    I've read that the tube configuration looking straight down on the Croft from left to right is
    tubes #1&#2 are the phono and #3 is the pre amp.
    The system sounds very good, revealing of upstream sources but with a tiny bit of harshness that
    I'd like to see if I can soften.
    I have a wide variety of music and I have to say the Harbeth's can carry it to my satisfaction.
    So what would be the protocol to start the process?
    Pre-amp tube first and then wait a bit or start first rolling the phono stage only?
    Any suggestions deeply appreciated.
    p.s.
    I have contacted Glenn about a month ago but he hasn't responded so I don't
    want to pester him.
    Thanks!
    I'm Stephen.
    Welcome to the world of Croft. Wise choice - see my post from yesterday on Glenn's superb customer service.
    Like many others who I'm sure will comment I have spent literally years swapping tubes in my many and various Croft preamps and power amps. I have a large box full of NOS and new tubes from dozens of makers. If you have the merest trace of OCD stop now before you go mad. LoL
    Seriously though the single thing I have learned is that as with all things HiFi in the end it all comes down to personal taste - the sound that best floats your boat which like as not will not be the same as mine or many others.
    After spending a lot of money on NOS Tesla's, Mullard's, RCA's, Mazda's TFK's Westinghouse, Sylvania, Brimar Philips etc etc but you get the picture all with varying appeals and dislikes I have come back around to sticking with (almost) what Glenn uses. In my 25RSLS line stage I use 3 (mine is modded to include an output buffer for a headphone amp) Tesla gold pin 12BH7a's and 2 Tesla gold pin ecc83s's in the power stage. I use a Tesla gold pin ecc99 in the power amps. This combo gives me a clear, neutral dynamic presentation that I like - others may not.
    Glenn will not comment on tubes I can tell you from many conversations he struggles to find consistent quiet non microphonic NOS tubes so sticks to the Tesla's.
    Others will I'm sure give you other equally valid opinions and suggestions.
    I presume your amp has the red print Tesla's Glenn usually uses? If it's only a tiny bit of harshness you want to change then try the gold pin versions for little money. Swapping to any NOS will like as not produce a bigger change.
    Hope you have fun and enjoy the adventure.
    Don't say you haven't been warned LoL
    Steve
    Sent from my Pixel 4a using Tapatalk
    Always a little further
    Good post Steve
    I'm Stephen.
    Good post Steve
    Thanks Alan
    I'm Joe.
    Hi Steve,
    Thanks for the detailed response.
    One very important consideration I left out was that I use the Croft for
    work.
    I'm a film /video editor and the unit is on at least 12 hours a day 7 days a week.
    I mentioned this to Glenn and my AD and they said no problem.
    I've found that the amp runs mildly warm,plus it's near a window
    with just enough clearance to not be harmfully vulnerable to the weather while at the same time
    get a mild breeze indirectly.
    So I'm thinking JJ's Gold pin per your suggestion,Gold Lions or I've just read about the Long Grid JJ's
    sold on Tube Depot...you have any experience with these tubes?
    Thanks
    I'm Stephen.
    Another reason to use new production valves IMO. The preamps do run a bit warm with all those valves but as long as you leave plenty of space above the top case it won't be an issue.
    No direct experience of the ones you mention. I have tried the expensive new production TJ full music and Psvanes but was underwhelmed.
    Quote Originally Posted by Stowa View Post
    Hi Steve,
    work.
    Thanks
    If you are wanting to stay clear of harshness stay clear of the Gold Lion's
    I'm Joe.
    Hmmm,that hasn't been my experience in various phono stages or preamps,but
    everyone's taste and ears are different.
    Anyway, what advice as to the procedure of rolling..
    Pre-amp valve first then wait a bit to analyse.
    or
    roll phono valves only first?
    Thanks
    I'm Stephen.
    Personally, I'd start with the phono stage valves
    I'm Joe.
    Thanks
