Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 103
Thread: Neurochrome Modulus-686
  1. #21
    I'm Kevin.
    Quote Originally Posted by hornucopia View Post
    What IS a Guardian circuit? Surge protection? Soft turn-on?
    And kudos to Stuart for observation!
    A speaker protection circuit.
    Kevin
  2. #22
    I'm stuart.
    I only know because when I was ordering the boards from Tom he explained that regardless of the configuration, if you are using the 686 boards you must have a Guardian for each channel
    Garrard 401, Jelco 750 with Shuggie, Ortofon 2M Black / ZYX Yatra 100, Project Phono RS with Sigma22 Linear PS, RPi3 + DigiOne + Linear PS, RPi3/1Tb SSD with PiCorePlayer + Linear PS, Perreaux Eloquence 250i 40th Anniversary with ES9038Pro DAC, DCG3 Pre-Amp, Neurochrome 8x2 Pre-Amp, Neurochrome 686 Power amp, Benchmark DAC2 HGC, Primare V25 CD player, Monitor Audio PL300, Sjostrom DCT03 DC Blocker.
  3. #23
    I'm stuart.
    One of the guys on DIYAudio did a great build guide:
    https://blog.andytather.co.uk/index....-build-thread/
  4. #24
    I'm Kevin.
    Quote Originally Posted by killie99 View Post
    Thanks. I have reconfigured the board. You have saved me some disappointment later in my build.
    Time to order the missing one.
    Kevin
  5. #25
    I'm Kevin.
    I found that one. It looks very tight in a 300 mm case. I was thinking going for 400mm.
    It is almost a shame to hide those transformers away as well...
    Kevin
  6. #26
    I'm Kevin.
    What did you guys use for a soft start?
    My Toroidy transformers have shipped (2 x 24V, 400VA) so I need to sort out a good soft start so I can test the Power 686 boards.
    Kevin
  7. #27
    I'm stuart.
    I used Tom's V1 ISS board - guess that isn't an option anymore as he's replacement it with a V2. Pretty much the same features though other than selectable soft start delay and emergency shutdown for Hypex and Purify boards.
  8. #28
    Location: Bristol, since 1978. Current house since 1996!
    Must find out if my 86 has one! Firebottle.....?
    Chris.
  9. #29
    No it doesn't but the 3886 power chip has a lot of built in protection.
  10. #30
    I'm Kevin.
    What are you using as a soft start Alan?
    Kevin
