Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: High end preamp wanted...
    I'm Tim.
    Default High end preamp wanted...
    Following the sale of my ARC Ref 3. Budget around £5k... what have you got?
    I'm John.
    I would suggest contacting Jonathan Billington at MFA, and getting an audition of Baby Ref, they are stunning things.
    Sent from my I3312 using Tapatalk
    Money may not make me happy.
    But it helps me afford the kind of misery I prefer.
    SYSTEM 1:
    Analogue.
    Brinkmann Bardo / 12" OL Enterprise Mk4 / Koetsu Rosewood Signature Platinum /BigBottle mk3 /MFA Baby Reference Pre/Nord One UP SE NC500M/Martin Logan Summit
    Digital.
    Docet Lector CDP-7TL mkiii/Pimped Bluesound Node2 + BOTW SBooster Lps/ Pimped Mk1 Jolida Fx Glass DAC.
    Wires etc.
    Audioplan Musicable ICs & TQ Black ll SC, assorted branded kettle leads.
    Target TT shelf & Alphason 5 shelf rack.
    Power Inspired AG1500S mains regen.
    SYSTEM 2: Back to the 80s.
    Garrard 401, RB250, A&R P77Mg / Mk1 Marantz CD63 SE / Sony TC-FX150 / Sansui T500L / Cambridge Audio C50 + 2x A50 as bridged monos (mid 80s Stan Curtis's design) / or KEF 104ab/ Original 80s Monster Cable IC, DNM SC / Target 5 shelf rack.
    SPARE KIT:
    A&R E77Mg
    Ortofon 2M Silver + Blue stylus
    Philips CD600
    Arcam Alpha 8P
    Pro-Ject DacBox S FL
    CCA
    FiiO Taishan
    Heybrook HB1 S2
    Q Acoustics 3050
    I'm Phil.
    agreed , i compared one to my arc ref 5 and it was extremely good . not too much in it .
    Eric Bibb
    I'm Mauro.
    I'm Tim.
    Thanks all, I would prefer balanced and active, but appreciate the suggestions.
    I'm Andy.
    Not sure I would look any further than Tron. Graham Trickers pre amps are quite special.
    Analogue
    401 / PU7 / AT33ev
    Digital
    Innuos Zen Mini Mk 3
    Topping D50s
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
    Quote Originally Posted by Tim F View Post
    Hi Tim
    Why ? Balanced is sadly very precarious involving precise summing with ensuring hot and cold arrive intact at your power amp. if its not summed precisely or amplified precisely you end up with phase errors, as either cold or hot, lead or lag.
    Active systems similarly contain many ( endless ) level amplifier/ speaker matching issues.
    The advantages of balanced are touted as reducing unbalanced noise. using instead opto coupling in your passive attenuation exampled by the NSL32SR3 http://test.lunainc.com/wp-content/u.../NSL-32SR3.pdf
    IMO has, when powered properly exemplary silencing of noise floor ie a black silent background, making balanced systems, left wanting what they can achieve.
    Lots to think about, let me know if I can help further.
    I'm Tim.
    My V140 monoblocks are fully balanced and only have balanced inputs. Thanks for the advice. I'm not buying new so will see what is about rather than targeting a specific make.
    Bump....
    Bump....
    You can use a preamp having unbalanced outputs with a power amp having balanced inputs. Just as you can feed a preamp having only balanced inputs from a source having unbalanced outputs. The reverse situation is more tricky.
    I'm Phil.
    Quote Originally Posted by Andy831 View Post
    good choice
    Eric Bibb
