Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: Rebuilding and modifying my Lentek head amp
  1. #31
    Quote Originally Posted by Frinpaul View Post
    Hi Marco,
    Thanks for such a prompt and detailed reply - much appreciated!
    I take your point about the original output cables being a potential bottleneck; I have thought that might well be the case, especially as one of the phono connectors on mine is slightly temperamental. Is it relatively straightforward to change the cables and, if so, could you recommend cables that would be an improvement? I'm afraid any internal work on the Lentek would likely be beyond me - actually, it was the fact that you mentioned that you had outsourced the work that initially piqued my interest.
    I agree that Duracells seem to be about the best match battery-wise. I was, though, very impressed with some Philips alkalines that I tried a few years ago - they were being sold in Poundland, and were the only batteries I've tried that I felt were (at least) a sonic match for the Duracells in the Lentek.
    All the best
    No worries, Paul, you're welcome. The rather 'flaky' nature of the stock connectors on the Lentek is well-known, but there wasn't much better around in the 80s! In terms of connectors, I'd use these copper ones from CMC, as they're very good quality and well priced:
    https://www.hificollective.co.uk/pho...a-sockets.html and in terms of cable, I used this Cardas Litz stuff, which is excellent. Keep the lengths as short as possible (just enough to reach the partnering kit, but with a bit of flexibility): https://www.hificollective.co.uk/wir...nect-wire.html
    And as for phono plugs, the sky's your limit. I used these: https://www.hificollective.co.uk/pho...mony-plug.html but you could just as easily use the slightly less expensive copper versions, in order to maintain a solid-copper contact connection with the CMC sockets: https://www.hificollective.co.uk/pho...mony-plug.html
    For me, you can easily hear the sonic improvements of solid-copper or silver plugs and connectors, over their brass counterparts. I also like the low-mass nature of the shells on the KLE Harmony plugs, as to reduce eddy currents, you want the least amount of metal on plugs as possible, and so contrary to what your instincts may tell you, in terms of getting 'value for money', the heavier and more solid the better is NOT the case...
    You want light but rigid, low-mass, non-magnetic shells on phono plugs, where for best sound, the only metal used is in the conductors themselves!
    In terms of upgrading the 'internals', should you wish to go there, I'm sure that Anthony would be more than willing to do the work for you, as he did for me, so just pop him a PM (anthonyTD) and it would simply be a case of sending the unit to him and agreeing the cost, in order to do what's necessary. Hope that helps
  2. #32
    I'm Paul.
    Hi Marco,
    Thanks for the info and suggestions, much appreciated. I certainly think my little Lentek deserves some new cables and sockets!
    Paul
  3. #33
    Definitely, Paul. If you fit the items I've recommended, or similar, I'm sure you'll be very pleased with the results! Let us know how you get on
  4. #34
    I'm Paul.
    Hi Marco,
    I was very interested to hear that low mass connectors are the way to go - I would have followed intuition and gone down the heavy/chunky route, so thanks for the heads-up on that. I must admit to a lot of prior scepticism when it comes to the sonic effect of cables and plugs, until I happened to change the turntable mains cable for something better (but not esoteric) that I had sitting around, and being very surprised at the improvement. More recently I have played around with speaker cables (having stuck with NAC A4 for 30+years!) and been very surprised by the sonically diverse results - so, I am now convinced that the smaller links in the chain do play a significant part in the overall result.
    Kind Regards
    Paul
  5. #35
    I'm Josie.
    How is this working out, Marco?
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
  6. #36
    Tremendous, it's a different beast - and best I've ever heard a Lentek! More on that later
    It's currently at Anthony's just getting some caps replaced we missed the last time, along with my headphone amp, being modified, which we discussed. So as soon as Anthony's done that and they're ready, we can sort out your Copper amp
    ATB,
  7. #37
    I'm Josie.
    Cool.. I'd be really interested in having the same done to mine too.
    Tannoyista.com
    Facebook
  8. #38
    Just a small addendum to this thread... In the end, the initial reported 'rustling noise' wasn't due to the original carbon resistors going bad, as first thought, but rather one of the output transistors going noisy!
    Even though the unit was sounding *massively* better, after the cap and resistor upgrades, the rustling noise was still present, so it was returned to Anthony to trace the fault, subsequently revealed as outlined.
    Therefore, in order to preserve the sound of the unit, as much as possible, as generated by the existing transistors/output devices, we decided to source some NOS ones with the same values, which eventually were obtained from a supplier in Holland, and now the unit, other than some residual hiss, when no signal is present (which is normal) is completely silent and sounds stunning.
    More on that shortly, including a summary of my overall observations on this project
  9. #39
    I'm BigBobJoylove.
    I have to say that it looks a LOT cleaner internally after the rebuild.
    Ben Duncan mains conditioner
    Samsung QE75Q90T 75" QLED TV
    Atacama SE24 stands
  10. #40
    Nice to hear it's been sorted out. Should make for an interesting read when you post your thoughts.
    PRE
