Results 1 to 6 of 6
Thread: FS: Squeezebox Classic (SB3)
    I'm Shane.
    Default FS: Squeezebox Classic (SB3)
    Squeezebox Classic (SB3) in white. Good condition and sounds as good as Squeezeboxes always do. I’ve taken off the original flimsy PCB mounted phono sockets and fitted more substantial sockets mounted to the case, because it seemed a bit vulnerable for tight-fitting phono plugs. Made no difference to the sound, but helped peace of mind. The original PSU packed up a while ago so I substituted a slightly beefier one, which tightened up the bass a bit and improved transients.
    Comes with its original box, remote and a very bog-standard phono lead.
    £35 plus £5 P&P.
    I'm BigBobJoylove.
    I built a battery pack to power my old Squeezebox - made a massive difference! Cracking streamers, it’s a shame Logitech turned their back on the Squeezebox.
    I'm gerald.
    pm sent
    I'm gerald.
    Shane you inbox is full
    Gerry
    I'm Shane.
    Hi Gerry, inbox now cleared!
    Time flies like an arrow.
    Fruit flies like a banana.
    I'm Shane.
    Sold!
