Results 1 to 10 of 11
Thread: Wanted / Recommendations: Small Bookshelf Speakers
    I'm Ant.
    Default Wanted / Recommendations: Small Bookshelf Speakers
    Hi
    Looking for a pair of small bookshelf speakers, ideally around 12 to 14 (max) inches in height, in a medium wood finish with black grilles.
    They will be used in a small room (3x5m) so need to have good clean bass with an open detailed sound.
    Will be used with a computer & NAS based audio / DAC and a Naim Nait 5i system
    Max budget is £200, happy to consider used but must be in good condition.
    Many thanks
    RO .
    I'm John.
    I would say have a look at the Q Acoustics 30xx series, great vfm speakers. Their Concept 20s are good aswell but only available in gloss black or white.
    Sent from my I3312 using Tapatalk
    Money may not make me happy.
    But it helps me afford the kind of misery I prefer.
    SYSTEM 1:
    Analogue.
    Brinkmann Bardo / 12" OL Enterprise Mk4 / Koetsu Rosewood Signature Platinum /BigBottle mk3 /MFA Baby Reference Pre/Nord One UP SE NC500M/Martin Logan Summit
    Digital.
    Docet Lector CDP-7TL mkiii/Pimped Bluesound Node2 + BOTW SBooster Lps/ Pimped Mk1 Jolida Fx Glass DAC.
    Wires etc.
    Audioplan Musicable ICs & TQ Black ll SC, assorted branded kettle leads.
    Target TT shelf & Alphason 5 shelf rack.
    Power Inspired AG1500S mains regen.
    SYSTEM 2: Back to the 80s.
    Garrard 401, RB250, A&R P77Mg / Mk1 Marantz CD63 SE / Sony TC-FX150 / Sansui T500L / Cambridge Audio C50 + 2x A50 as bridged monos (mid 80s Stan Curtis's design) / or KEF 104ab/ Original 80s Monster Cable IC, DNM SC / Target 5 shelf rack.
    SPARE KIT:
    A&R E77Mg
    Ortofon 2M Silver + Blue stylus
    Philips CD600
    Arcam Alpha 8P
    Pro-Ject DacBox S FL
    CCA
    FiiO Taishan
    Heybrook HB1 S2
    Q Acoustics 3050
    I'm Keith.
    Quote Originally Posted by Robert Onion View Post
    Hi
    Many thanks
    RO .
    Checkout the Eltax monitor iii’s. They’re well thought of and you might find a bargain second hand, there’s even a Bluetooth model
    I'm Geoffrey.
    I use a pair of Dali Spektor 1s - very petite, just 9 inches tall. This is in my study which is only just over 2m x 3m. I've been very pleased with these, and I like the Dali sound. Perhaps Spektor 2s might suit your slightly larger room - still within your budget, I would think.
    Regard,
    Geoff
    I'm Adrian.
    New DALI Spektor 2 around £199 or less HiFi recommended , 83dB sensitivity a bit low
    New Monitor Audio Bronze 2 again around £199 easier to position as front ported see https://www.whathifi.com/naim/nait-5i/review
    2nd Hand Mission 771 or 771e book shelf speakers, £100 to £200.
    I'm Ant.
    Super thanks for the replies
    If anyone has anything surplus to requirements that might fit the brief please drop me a pm
    Would be happy to consider a nice pre-owned pair of speakers as well
    Quote Originally Posted by Westendboy View Post
    I used to have a pair of Eltax III speakers for AV duties and can recommend them. They are available for ~ £150 on-line.
    I'm Keith.
    Yep, saw them looked nice in calvados (bit lighter than walnut) with black grills. Forgot to mention bi- wiring or bi- amping possible, 89dbl I believe.
    I'm Keith.
    I have a pair in black I’m using for tv duties
    I'm Laurie.
    Pro ac hexa, Unused recently. Great sound from tiny box, £600 new I think, £200 now
    Vitus sia025, brinkman Bardot deck and nyquist dac,Boenicke w8se, Melco server, audiovalve sunilda phono, kondo Cables, lots of Stillpoints, Ess rack.
    Worldwide 40 million chickens, ducks, and geese die daily for the plate, savage and wasteful.
