I have been thinking of getting a mains regenerator for some time, since my mains here hovers around 250v and is not too good in terms of distortion nasties either. Martin T is an advocate of the PPP and his system certainly sounds pretty good fed from one. So a few of weeks ago I was about to buy one off eBay when I noticed a one year old example on http://hifi-adverts.co.uk/ , so I struck a satisfactory deal and it's been with me for the last 2 weeks, feeding my system (listed below).
I thought that the PPP is a regenerator, like the ExactPower that I tried before and did not particularly rate; however it's a clever device that applies on-the-fly correction to the incoming mains. At least that's how I understand it, but anyone curious can go to PS Audio's website for technoblurb. Whatever, this compact box can supply up to 1500w of power, which is enough, without getting red hot or inflating the electricity bills. It can be set so that when turned off, the outputs are still live, which is novel, but nevertheless points to the PPP being a bit like a piece of wire with clever electronics applying correction signals as required. Maybe that's why the quality of the incoming mains lead is so important, as I found out. The display is quite informative, showing the incoming mains voltage, incoming mains distortion, output voltage and output distortion. There's a small set screw underneath for adjusting the output voltage.
Since my mains is very high, I wanted to set the output voltage to be no more than 230v, but I soon found out that the PPP has a limited range of adjustment. I could get it to a tad over 230v, but the distortion rose to very nearly the same as on the incoming mains. Adjusting to 235v resulted in output distortion of 0.4% against around 2.2% on the input, and all my gear seems happy with that.
One option is something called 'Multiwave' which is supposed to improve efficiency of power supplies; however I'm not sure that I can detect what it does. If I can sense anything, it's slightly in the negative, so this option remains switched off. Of much more interest is the 'Cleanwave' option, which applies a degaussing signal to demagnetise transformer cores connected to the PPP. It works - the system sound is much more graceful after a 60 second burst of Cleanwave. All options are available via the remote control, which is handy.
What about the sound, then? In short, I now get the same sort of 'late night' listening bliss at any time of day. I superficial terms, the bass is cleaner and deeper, but it is the lack of hardness and stress that makes listening a constant pleasure. I've been enjoying Solveig Slettahjell's CD 'Silver' and this has been simply breathtaking since the PPP has been set up properly - astonishingly atmospheric, detailed, intimate. Simply lovely, and my neighbour is probably sick to the back teeth of this Norwegian singer now, but I am not!
I mentioned mains leads and this definitely warrants a few more words. I did not have enough quality leads (Vertex Roraima with Furutech uber-bling connectors) to hook up all the gear as well as the PPP, so I made do with the supplied kettle lead. The resulting sound was OK, but not exactly inspiring - certainly not good enough to buy the PPP had I been demming it from a dealer. Moving one of the Vertex Roraimas onto the incoming mains indicated what the PPP could do, but it was a PITA swapping leads over from CD to vinyl etc. I could hear the potential, though. Luckily, I had the option to try some more Vertex leads that are being flogged off, so in went a Roraima+ lead, which I believe contains some mains filtering as well as acoustic filtering (the ordinary Roraimas have acoustic filtering only). Dear God, what a difference! The system has literally come alive with such power, grace, dynamics, tonal colour, etc, etc. It's completely wonderful! But the PPP would not be doing so well without such a good mains lead. Reading Martin Colloms' review in HiFi Critic, he came to much the same conclusion.
So, I am happy to have bought such a transforming piece of kit for not far off half the price of a new item. It's an audiophile bargain.
