Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: What headphone amp should I get?
    Indeed so, although in terms of powering this particular unit safely, unnecessary
    I'm Ian.
    Thanks to everyone for the advice and suggestions/recommendations. The reason for wanting a decent headphone amp is I moved to a new flat a few months ago and I only have one neighbour but she complains at the slightest hint of noise so I think she might explode if I set up my system. Once I've been here a while I'll give it a try but I don't want to rock the boat with my landlord right now. I'm currently using a pair of Sennheiser in ear phones that sound really nice but they do lack the depth and immersion of good over ear units. The little Creek amp works well with the ear buds but just hasn't got the guts to power either of my Sennheisers or my Koss Pro4 AAA. I'll report back when the headphone system is up and running. Once again thanks for the help.
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
    I'm inthescottishmafia.
    An alternative is one of these-
    https://www.analogueseduction.net/he...e-adaptor.html
    I’ve just acquired a set of Dan Clark Audio Ether 2, and was going to spring for a Benchmark headphone amp to go with them, but after a lot of research I decided to go with one of the above units, which I’m still awaiting. As long as your amp is quiet enough one of these will provide all the drive required, something planars need a lot of. Most of my research says this way sounds better than using a headphone amp.
    Hunter S Thompson
    Not sure which planars you are using, but I had one of these with my HE6 and found that I preferred the sound directly from my amp rather than via this box. I rigged up a spare cable with banana plugs and drove them directly from a 1000ASP ice power amp, that's 1000wpc into 4 ohms but thankfully less into the c. 50 ohms of the HE6
    I did in fact accidentally pass though an unattenuated signal to the headphones once (while not wearing them) and didn't realise for a few seconds until i heard the music coming out of them. Fortunately they seemed to have been none the worse off as a result. They really were some headphones!
    Sent from my HRY-LX1 using Tapatalk
    I’m using Dan Clark Ether 2. Was going to make my own, but by the time you add up the cost of all the parts you’d be close to the price of this. I’ll try driving directly too, and try swapping resistors in the box if the sound isn’t entirely to my liking. The HE6 like a bit of juice by all accounts. :-)
    Hunter S Thompson
    I'm John.
    Get one of these mate (as I did), and be prepared to be blown away: https://www.ebay.co.uk/itm/2019-New-...72.m2749.l2649
    Sounds like something at least five times the price!
    Plus, it's totally safe on UK mains.
    Hi Marco - are you still happy with the Lehmann headphone amp? I'm on the search for a headphone amp, so interested in your opinion on this one.
    Cheers
    John
    Technics 1210/Mike New Bearing/Jelco SA750d/Goldring 2500/Paul Hynes SR5 21/27.
    Cambridge Audio 840c CD. Squeezebox Touch. Synology NAS.
    Teac A-3440.
    Beresford Bushmaster.
    Quad II monoblocks....Quad 44/405.....Croft Micro.....Cambridge Audio 840.
    Celestion Ditton 66.....KEF Reference One
