As per the title I'm looking for a headphone amp capable of driving my Sennheiser HD650 and HD600. I've been using a Creek unit but it's not up to the job. My budget is around £300 and I'm more than happy to buy a used amp. Cheers.
Turntable
CD
Network Player
Cambridge NP30
Amplifier
Speakers
Cables
Headphones
I like my Graham Slee Solo Ultra Linear. You may find one 2nd hand in budget.
There may be others, but I have no experience of them.
Kevin
Rega EAR MKII drives 600/650's well.
Graham Slee Novo is pretty good as well.
S.
Shane Lonergan.
Decware's headphone range:
ZH1 battery
https://www.decware.com/newsite/zenhead.htm
CSP3
https://www.decware.com/newsite/CSP3.html
Taboo Mk.IV
https://www.decware.com/newsite/TABOO.htm
Johnny Dodgem.
Cartridges vintage MMs including Pickering xsv-4000/xsv-3000 : Stanton 881s/D81 : AT140LC/VMN40ML
Spinners hot rod 1210 (Jelco 750D, Origami, Ammonite, Longdog, Vantage, Achromats) : Pye G63 & Garrard AT6 : Two full custom Lencos : Kenwood KD-650D
Streaming Qobuz : BluOS & Node2 (Fidelity Audio modified) : RME ADI-2 DAC
Pre-amps Tron Seven (GT modified) : Conrad Johnson EV1 : Croft Micro 25 : Decware ZStage
Power Amps PrimaLuna ProLogue 5 (KT120) : PrimaLuna ProLogue 4 (KT77)
Speakers The Edingdale : Meadowlark Hot Rod Shearwater
Ifi Zen Can looks good for the cash. Should be able to drive pretty much anything.
https://www.futureshop.co.uk/ifi-aud...xoCCjIQAvD_BwE
Hunter S Thompson
Get one of these mate (as I did), and be prepared to be blown away: https://www.ebay.co.uk/itm/2019-New-...72.m2749.l2649
Sounds like something at least five times the price!
Plus, it's totally safe on UK mains.
It says 220 VAC in the listing, which is fine if your mains voltage averages out as being lower than 242 VAC (the spec is based around +10% and -6%)
The European standard is for 230 VAC, which with the +10% gives a high voltage of 253 VAC, which is too high.
Safe in some parts of the UK is a better description.
Chris
Common sense isn't anymore!
Hi Chris,
Exactly my thoughts when I bought it, hence why I was considering installing a step-down/bucking transformer.
However, after Alan (Firebottle's) comments here: https://theartofsound.net/forum/show...69#post1220469 regarding double-insulated, fully-regulated supplies (the main reason I bought this unit in the first place), I didn't bother with a bucking transformer, and subsequently have experienced no issues whatsoever in the month or so I've used it since.
Indeed, it doesn't even get hot, after being switched on for hours, and my mains has been measured at 242V
Therefore, for that reason I'd have no qualms whatsoever recommending this unit to anyone else, on either the grounds of safety or sonic ability; indeed in terms of the latter it is superb, and as such offers very high SPPV. Think of this as a £500 device (minimum), for £400 less!
And one of the great things about it, which can be a problem with some lower-sensitivity headphones, it that it has oodles of gain, and so can drive ANY set of headphones no matter their impedance value. It's impeccably built too, plus the seller is a joy to deal with - builds them to order, normally completed in 4-5 days and shipped immediately after that. Mine was delivered a few days later.
In short, I can't recommend this headphone amp enough, or indeed the seller!
always handy having a variac in the house in case. good for warming up a machine thats not been on for some time too.
