Results 1 to 5 of 5
Thread: Cartridge Man Isolator - what glue?
    I'm Kevin.
    Default Cartridge Man Isolator - what glue?
    Having recently got hold of a Houdini, I am tempted to try my Cartridge Man Music Maker on it.
    The only issue is that it looks like the cartridge is glued in place, so I am reluctant to remove it, unless I can replace the glue, so does anybody know what glue is used please?
    Kevin
    I'm John.
    Am guessing the CM would use fine double sided tape, similar to double sided carpet tape.
    The glue/tape is easily removed with lighter fuel (petrol).
    Sent from my I3312 using Tapatalk
    Money may not make me happy.
    But it helps me afford the kind of misery I prefer.
    SYSTEM 1:
    Analogue.
    Brinkmann Bardo / 12" OL Enterprise Mk4 / Koetsu Rosewood Signature Platinum /BigBottle mk3 /MFA Baby Reference Pre/Nord One UP SE NC500M/Martin Logan Summit
    Digital.
    Docet Lector CDP-7TL mkiii/Pimped Bluesound Node2 + BOTW SBooster Lps/ Pimped Mk1 Jolida Fx Glass DAC.
    Wires etc.
    Audioplan Musicable ICs & TQ Black ll SC, assorted branded kettle leads.
    Target TT shelf & Alphason 5 shelf rack.
    Power Inspired AG1500S mains regen.
    SYSTEM 2: Back to the 80s.
    Garrard 401, RB250, A&R P77Mg / Mk1 Marantz CD63 SE / Sony TC-FX150 / Sansui T500L / Cambridge Audio C50 + 2x A50 as bridged monos (mid 80s Stan Curtis's design) / or KEF 104ab/ Original 80s Monster Cable IC, DNM SC / Target 5 shelf rack.
    SPARE KIT:
    A&R E77Mg
    Ortofon 2M Silver + Blue stylus
    Philips CD600
    Arcam Alpha 8P
    Pro-Ject DacBox S FL
    CCA
    FiiO Taishan
    Heybrook HB1 S2
    Q Acoustics 3050
    I'm Kevin.
    Thanks. Looks like it is a glue from 3M.
    Kevin
    I'm Neil.
    I had this same discussion with Len on Friday. The isolator is a single use item, not transferable. It’s adhered by a special 3M film glue, not available to the public.
    I'm Kevin.
    Thanks for the info. I am glad I have left it alone now.
    Kevin
