Gone are the days of me spending much dinero on wanky wires, but just wondering if one of these would make any difference.
What have you got?
What have you got?
Bluesound Node 2i
Audio Analogue Pucinni SE
B&W DM607 s2
Klotz ic’s
You might find it easier to use an IEC adapter as I have done - then the world is your lobster in terms of mains leads!
Cheers Dave,
I remember some years ago using something similar on a KI Marantz CD player
Bluesound Node 2i
B&W DM607 s2
Klotz ic’s
If you use Amazon, this one would do.
https://www.amazon.co.uk/dp/B00BJ3VG..._TvFCFbBJK6NPW
'ANDSOME IN THE SUMMER..'ORIBBLE IN THE WINTER. Barney Milne
Cambridge Audio CXN, Seagate nas drive, Michell Gyrodec SE, SME309, Benz M2 Ruby cantilever, Denon DL103, Primare R32, Densen D20, Densen D30, Cambridge Audio 840A V2 integrated, Pioneer SX-N30AE Network Stereo Receiver, Roksan Darius speakers, Technics speakers, Canon speakers, Bastanis Dragonfly Horns, REL Storm III sub, Target R1 speaker stands, Atacama Equinox.
thats a good buy alan , the plugs alone cost that
Eric Bibb
Had one of these Mark Grant jobbies in the past and it was quality and great value https://www.markgrantcables.co.uk/uk...e-8-connector/
My System:
CDP - Pioneer PD-91
+ One for the Mark Grant cable they are as good as you will ever need with regard to build quality until you start to get in to the lunatic fringe.
Yes, I was looking at that already.
Bluesound Node 2i
B&W DM607 s2
Klotz ic’s
