2.4v obviously. Even if it isn't the correct value the worst that will happen is that it will go pop and you've wasted 99p!
If you could measure the voltage across where the diode would go before you order the replacement, just in case it might be a 24v one. I doubt it, you could always order 5 of each and get a whopping 2p discount....
I would suggest trying the 2.4v first, squirting 24v around might cause damage to other components if it's not correct. You only need to put the wires through the holes and twist them so they make contact and quickly flick on the power. If nothing happens then maybe try the 24v but be ready to switch off quickly if you smell anything!
Good luck!
