Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
Thread: Cable Burn In
  1. #21
    I'm Bruce.
    In my experience some cables do "burn in" over time and some seem not to. Years ago I borrowed four sets of expensive speaker cables to audition over a holiday weekend and see if there was any difference, one set being new (Transparent Audio) and the others used demo stock. The Transparent Audio was all over the map sound wise. For a bit it seemed to have phase issues, then that went away and the bass was bloated, etc. After about 30 hours it seemed to settle and sound right. Even once settled, my partner and I both preferred the sound of one of the other cables, which happened to be the one I liked the looks of the least.
    I ordered the preferred one (MIT) which came new and changed a little over the first couple days but not nearly as much as the Transparent Audio.
    I too notice that after soldering work the sound in a component sometimes takes a few minutes to sound right, so I've gotten away from any critical listening immediately after a soldered modification.
    Bruce
    Theories are not so much answers as questions, to be supported or undermined by experience & testing.
    Source: Audiolab 6000CDT > Calyx 24/192 DAC
    Amplification: Pass-design B1rev2 pre-amplifier > Neurochrome Modulus 686.
    Loudspeakers: Proac Response 1SC
    Cables/stands: spkr: MIT MH-750 biwire; IC: HT Truthlink; Target stands, sand-filled; Excel Cat6A 23AWG UFTP & 1attack.de Cat.7 SFTP.
    Other: Balanced AC transformer to hydra mains distr; Bass traps & Acoustic panels; Isolation: Inner tube & roller bearings; 3xZyxel ES104A switches in series w/Vreg upgrades.
  2. #22
    I'm Gary.
    There's no point asking for a scientific explanation because there isn't one. It's either due to some unknown unknown or it's the mind playing tricks combined with a less than rigorous testing procedure.
    Either is possible, but one is far more likely than the other.
    Onus on you Martin to say why that statement is true.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  3. #23
    It's either true, or there is a third possibility I'm unaware of.
  4. #24
    I'm Gary.
    Here's a theory to consider:
    No horse in this race, in my own setup with my own ears I hear what I hear, but you mentioned a third possibility?
    Not mine, but this one doesn't seem unreasonable.
    As I said a lot of variables and nothings really black and white.
    Agree there can be a psychological component, hifi's rife with snake oil theories and those that take advantage of that for profit.
    Just throwing this out there
    "Breaking in" a cable has everything to do with the insulation - not the wire itself. The insulation or dielectric will absorb energy from the conductor when a current is flowing (music). This energy absorption causes the dielectric's molecules to re-arrange themselves from random to uniform order. When re-arranged the dielectric will absorb less energy and consequently cause less distortion. The cable is now broken-in and sound improves. To ensure the cable stays broken-in it must remain connected and the components left on. If no signal is present in the cable the molecules will re-arrange into a random state and break-in will have to be repeated. Length of break-in varies from 100-500 hours.
    the preamp doesn't usually have to be energized, but the input that you have those "cooking" cables connected to needs to be selected in order for signal current to be traveling through the cables of interest. If there's no load termination at the end of those cables, then no signal current flows & hence no breakin is occuring.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  5. #25
    I'm Clive.
    "Breaking in" a cable has everything to do with the insulation - not the wire itself. The insulation or dielectric will absorb energy from the conductor when a current is flowing (music)............
    It’s for this reason that Audioquest attaches a battery to the dialectic of their higher range cables.
    TV LG55B7 OLED
  6. #26
    I'm Bruce.
    ..."Breaking in" a cable has everything to do with the insulation - not the wire itself. The insulation or dielectric will absorb energy from the conductor when a current is flowing (music). This energy absorption causes the dielectric's molecules to re-arrange themselves from random to uniform order. When re-arranged the dielectric will absorb less energy and consequently cause less distortion. The cable is now broken-in and sound improves. To ensure the cable stays broken-in it must remain connected and the components left on. If no signal is present in the cable the molecules will re-arrange into a random state and break-in will have to be repeated. Length of break-in varies from 100-500 hours.
    For cables, I'd also heard from some no longer remembered sources that it had to do with the dielectric, though i'd not heard some of the specifics given here. I'd be curious who this quote is from... unless that would feed the cable wars.
    Bruce
  7. #27
    For an insulator to 'absorb energy' it must conduct it, assuming we are talking about electrical energy. Or would this be some other sort of energy? Having a conductive insulator must surely be wrong.
  8. #28
    I'm Kevin.
    All insulators conduct.
    Just not very well.
    Kevin
  9. #29
    Just not very well.
    And all conductors insulate.
  10. #30
    I'm Gary.
    Quote Originally Posted by brucew268 View Post
    In this place....
    Probably.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
