Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: new Computer keyboard - recommendations?
    Default new Computer keyboard - recommendations?
    I need to get a new keyboard. Looking for something that has keys with the feel and quality of the old IBM or Tandy machines of the 1980s. Don't want wireless and must have numeric keypad.
    Budget up to a ton but I'd rather not pay that much.
    Had a look on line but the choice is vast and most of them look like tat. Any help gratefully received.
    Picked up a Dell keyboard in a boot sale for about a fiver a couple of years ago. It replaced a previous Dell keyboard, where some of the letters had worn from much use.
    I'm Adrian.
    You may want to look at the Cherry mechanical keyboards:
    https://www.cherry.co.uk/products/of...s.html?cat=404
    My favourite is the G80-3000, reminiscent of the original IBM AT keyboard of yore:
    https://www.cherry.co.uk/cherry-g80-3000.html
    Available here for £90:
    https://www.amazon.co.uk/Cherry-WHIT...10PZMY6M7JH004
    I'm using an Acer keyboard that came with a new PC. It has proper hard buttons with a good tactile operation and USB lead. Probably loads on ebay.
    Quote Originally Posted by VillageIdiot View Post
    I like the look of that - expensive but it will get used 40 hrs a week so maybe worth it.
    Looks exactly like my Dell.
    Maybe Cherry make keyboards for others on an OEM basis.
    I'm Rob.
    I can recommend the Keyboard Company. They sell top quality keyboards. I've bought couple of great keyboard from them (but they don't have numerical keypads - so no go for you).
    Rob.
    Powered by crossed fingers and clenched buttocks
    I'm Gary.
    Company called Unicomp makes buckling spring mechanical keyboards using the original IBM Model M moulds.
    Not QUITE as good as the original, but not a couple of hundred quid for a 30yr old piece of plastic either.
    In your budget Martin.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm Pavel.
    I don't know about their recent keyboards but my Unicomp M stopped working after ~3 years of service - it turns out there is a design flaw, one part of the plate rubs against the membrane and eventually breaks one of the traces. Also they're non-serviceable (unlike the old IBM Model M) since the controller board is simply pressed onto the membrane, once you disassemble it, good luck aligning the pads properly.
    The Keyboard Company sells a lot of great keyboards, I would recommend Filco - it's a high quality Japanese brand of keyboards. They use the same switches as Cherry keyboards but their build quality is 15 times better. I have two Filco keyboards and one Cherry G80-3000, the difference in sturdiness and weight is startling.
    Thanks but both keyboards are over my £100 max budget which in any case I've already frittered away on some other tat.
    Both the Filco and Unicom look like what I'm after though. Just surprised it is so expensive to buy a decent keyboard.
