They are great when set up to your ears. Although a little better on cable, a good Bluetooth connection and you gain freedom.
The avantree leaf for pc is super. Great range too.
I'm Ward.
I'm very lucky as a few years ago I managed to pick up a pair of Sennheiser HE60s and a class A Head Acoustics activator to drive them, they replaced a Stax 404 pro system that my son now owns. I also have a pair of Hifiman HE500s driven by an Icon audio HP8 using Psvane output tubes. Portable duty is covered by a pair of B&W P3s which I use with a Fiio DAP.
You might get an improvement with the Avantree DG60 or similar with the CSR8675 chipset, as it would support Aptx HD, as the Nuraphones do.
I'm Mandeep.
I’ve just got beyerdynamic dt 1770 pro. Took some getting used to after using meze 99 classics for 3yrs.
Very good isolation and not at all ear piercing when when playing loud.
Merry Christmas to all..
I'm Robin.
Two sets of headphones requiring different amps:
Stax 009S + Focal Stellias.
Robin. mit ARC CD9, ARC ref 5 / darTZeel power + magico v2. Clearaudio Innovation wood / Phantom ll / Lyra Atlas / Aurorasound Vida,
Stax 009S cans.KGGG headamp. all connected with wires. Auralic Aries - Aqua La Scala. Manley Absolute. Focal Stellias. HD800S Hyland headphones - Venus
Also a Nuraphones user here. Love the flexibility of using cable or bluetooth connectivity. They stay charged for a long time so all in all very pleased with them.
The earpiece fitting does take a little getting used to but now I do not even notice it and I really enjoy listening to the music.
I also bought a set of Nuraloops from the same company but they are getting less use, although they use the same technology, as I find they do not fit quite so well. Reminds me I should give them another go.
Beyer DT911 that I have had for years. Status Audio CB1 closed back. Philips Fidelio X2HR which are remarkable for the money. Chord Mojo feeds all three successfully.
