Jolida Mk3 FX Glass dac fully upgraded
Great dac in original box.
Output tubes are of the best and extremely rare now - I cannot find any to buy anymore, so a gift in that it is included with this dac. Raytheon CK5755 with adaptors but the yellow label and are the ‘Reliability Controlled’ versions.
Output caps are the sweet Modwright Oils
Low voltage caps swapped out to Nichicon and Elna
High voltage caps to Nichicon KX, Panasonic and Audyn
Audio Note silver plated RCA’s on the output
Cast silver wired on output
Chassis dampening with SoundCost
Feet now EAR small compliant types
IEC input now Furutech type gold plated
Fuse a Wilbrand from Germany (silver plated element and the ceramic tube is filled with ceramic beads for mechanical stability - quieter)
Volume pot controls both the headphone socket in the front as well as the RCA output - so can be used as a digital pre
£490 incl post
