Results 1 to 5 of 5
Thread: Akai DD TT, Goldring Electra, CA640 stage
    I'm Tom.
    Default Akai DD TT, Goldring Electra, CA640 stage
    The TT is an Akai AP-206C in the rarer black/graphite colour, not unlike this one. Condition is almost the same too apart from a lack of lid, the armrest clip is broke and it works fine with rock steady speeds.
    Brand spanking new Goldring Electra MM cartridge fitted and has played only one side of an LP.
    Cambridge Audio CA640P MM/MC phono stage. The LED doesn't work and the wallwart power supply has done the usual trick of the top and bottom casing having an argument, so they are held together with tape to make it safe. You could fit longer screws because only the top couple of mm of the internal mounting posts have broken.
    I would like to sell the whole lot together as a package, so you get a plug-and-play vinyl player and I have less fannying about with multiple packing and postage.
    Hi Frank,
    Your piccie's not working, dude.... I suggest you host it through Photobucket or Imageshack, rather than link it through VE
    I'm Nobody.
    Hi Frank,
    Good
    I'm Tom.
    Hi Frank,
    Done
    I'm Tom.
    Quote Originally Posted by Andre View Post
    Good
    Listen 'ere Gladys, just be greatful it aint a photie of me
