I'm Alex.
Anthony et al, I think that we are at cross-purposes and you are wrong. I have not found an answer that says how to remove the spring loaded terminals from the plate in-situ. Removing the drivers was a no-no option from the beginning. The only person who removed them was Spendorman he does not remember how he did it. I could have gotten a drill or a pair of pliers and do it, but is was not the point.
Did you read my post, Horatio? What exactly in your opinion is wrong with the binding posts already on the speakers, and what do you intend on replacing them with?
Hi Marco, I just want to replace the speakers posts because I want to use a lower gauge cable, not exotic or expensive, just 14 or 12 gauge wire, I have a box full of them. The Devons' posts accept 18 or higher gauge. It would be perfect for a very short run, for example with monoblocks sitting next to each speaker, but that is not my case.
There are no screws in the binding posts, they are spring-loaded, the whole is for 18ga or larger. I simply want to replace them, I have several superb WBT and Vampire posts at home.
You can't remove the terminal posts from outside the cabinets.
Ok I would have thought if the springs are strong enough to hold a cable they could hold a spade but I've not actually seen them so I could be completely wrong.
Sent from my HRY-LX1 using Tapatalk
I'm Dennis.
