Well they are looking good Andrew.
much tidier
Excellent. Did you make new frames? So how are they sounding?
Sent from my moto g(8) plus using Tapatalk
Regards
Gerry
No they are the original frames , I had to sand them and 2 pack wood filler them , sand them again, 3 coats of pva ( each coat made stronger) sand them again them apply eco-stik 328 to the panel and the real wood veneer, I screwed up on the first attempt and had to start all over again .
They sound very good indeed , I will make some plinths at some point and then I’ll angle them at 90 degrees .
Absolutely the most massive upgrade for Maggie's and Apogees is frame stiffness/rigidity.
Well worth making or getting some bespoke aluminium stands made that support the rear as much as feasible.
You won't believe how much better things get with a rigid frame. Believe me I know and it is the testament of countless Maggie users.
Not sure what your using? Any chance of a rear shot?
Looking good BTW.
