Results 1 to 3 of 3
Thread: LS40 Measured data
    I'm Colin.
    Default LS40 Measured data
    OK a 3M length measure as below:-
    Capacitance at 3 metres = 100pF Each single conductor red or black
    Inductor on each single conductor is 3.3uH at 3 Metres
    Leakage/Common Mode inductance Less Than 0.9uH at 3 Metres
    Resonant frequency a single conductor red or black 15MHz at 3 Metres
    Total Resonant frequency in normal use i.e. 8 Ohm load is 8.76MHz at 3 Metres.
    Longer length will have more capacitance/inductance and the resonant frequency will reduce.
    The loading on the amp is very very small and at audio frequency would not be noticeable i.e. 10Hz to 25KHz
    Phase change from input to output at 100KHz was less than 1Deg.
    TQ and others would never post this type of info.
    Thanks Colin how does this compare to ls25 for phase ?
    I'm Colin.
    On a 3M lenght the first batch of LS 25 at 100KHz was over 1.54DEG
Tags for this Thread
