Originally Posted by
Marco
I've never used or experienced air-con for heating, only cooling, but intuitively to me it just seems wrong. Does it give a natural or an artificial kind of heat?
I'm curious - what's the difference between the heat from air-con and that from say a radiator, apart from one will blow the heat round the room? Heat is heat, surely? Unless by natural heat you mean log fires, which in Vegas hotels are probably thin on the ground.
If you bought a portable air-con as suggested, you could run it in the evening (or even all day long) to not only cool the air but draw the heat out of the walls, then switch it off at sleepy-time I bet that would work.
Oh and there's nowt wrong with Ready Brek, you just need to lower your standards a little. A bowl of tasteless slop never hurt anyone - look at Oliver Twist, he turned out ok.
