I'm Dennis.
For room reflection problems I mount a curtain on walls as though over a window, heavy velvet from charity shops.
Thanks Steve, good to have your opinion, as you've owned most of my hifi! I guess then issue is either my room, or how I hear sound, I am quite sensitive to discordant sound, whether its jazz trumpet or screechy guitar, but that is amongst my favourite music. My cd player is well old, could do with a once over, its got a high quality chip and mechanism.
There is absolutely nothing wrong with the Legacy quality control IMO, have owned a pair of Legacy Arden's. There are lots of views and arguments about vintage versus new Tannoy's, you can go down the proverbial rabbit hole if you get involved in that. My Arden's were superb and from what others have told me the rest of the range a pretty special including the Eaton's. If Sue would let me I would go back to a pair tomorrow but that is not going to happen in a hurry and thankfully my WB Vectors do 98% of what the Tannoys do.
It is a good thing to remember that manufacturers are aiming to improve products, Tannoy when re-introducing their Legacy range they would have done just that, they also now have the benefit of modern technology to use to improve designs and manufacturing.
This review is from Paul Rigby is probably as close to the truth you will get about them. https://theaudiophileman.com/eaton/
System sounding a bit better now overall, getting rid of that large chest of drawers definitely a good idea, allows more room for speaker positioning, speakers are away from both walls, not as Audio note recommend, but they sound better that way to me. Bit more content with sound, though sharpness in high notes persists. Some nice wow moments, with imaging etc, still not tried with rock though, as need to set up TT shelf on wall, and only have jazz on cd. This is with the S500, after I replaced all the valves with Gold lions, might try changing the valves in the Soro too, or I may not, really doesn't seem to be much difference in quality between the two amps, the S500 was modified by AD audio so is far from standard.
I'm brian.
Got the mayware set up yet ?
