Agreed, I'd have thought them more than adequate for this purpose.
Hunter S Thompson
Certainly in the context of Mike's system/room, Adrian's suggestions are a cost effective approach, and worth trying out I would have thought.
I'm now thinking the Audio Note Js tend towards a boxy and constrained sound, somehow something is missing, not a fully fleshed out sound. The treble is also killing my ears, time to try something else me thinks.
Tried putting El34s in the AN Soro but they didnae fit! Wot is happening?? They are taller than the 6551s in there already. They touch the screw on case of the amp.
Mike, that is not my experience with Js, you're so close to AN, I think I'd ask them to give them a check over and I think they calibrate the crossover if there is some drift. Gotta be worth the cost of an hours labour.
Are you confusing 6551 with 6550 and 5881.You can sub an EL34 with a 6p3S-E.Sound very good and can take lot of stick.I've used them in my Radford for a good few years without any problems and a lot of guitarists use and recommend them.
Nothin' I do don't seem to work ,it only seems to make matters worse!. Jagger/Richards
Mate if they're that out of spec from what you say get someone round to see if they think the same as you. Borrow another valve amp if you can.
Sent from my HRY-LX1 using Tapatalk
