Originally Posted by
anthonyTD
The output valves are 5881, which are a military grade 6L6GC, nothing realy wrong with those as far as being a good workhorse, the next one down look like JJ 6SN7, which can easily be upgraded by either NOS versions, Brimar's for instance may suit your pallet in this instance Mike, as for modern equivilents the Tungsol's are ok, as are some from Shuguang [chinese] first valve, if you can make do with a bit less gain, and there is already an ECC83/12AX7 fitted, then you could try a Military spec ECC81 CV4024 in there, or a 5751, hope this helps.
A...
