Page 16 of 58 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 574
Thread: Valve amps, great with Jazz, shit with everything else.
  1. #151
    Leave such things to the EEs and builders of equipment. End users should simply judge using their ears: that's the subjectivist approach, and indeed the AoS one!
    So I'm going to have a demo of every (for example) amplifier in existence before I make my choice of which one to buy? It isn't practical to select hi-fi by listening alone.
    You have to narrow it down to a point where it is practical to test them using your ears. So what is the best way to compile that shortlist? Look at the engineering quality and the measured performance and use it to rule out the tat.
    You may have a good system but how do you know you couldn't have had a better system and maybe for less money? You can't listen to everything that's available, let alone every combination of everything that's available. You'd have to live to be a million years old.
  2. #152
    You just do some research on whatever you're intending to buy (and in that respect I largely use user feedback, not specs, for validation of its potential efficacy), then make a judgement call on it, and trust your gut instincts.
    I haven't 'auditioned' anything, or been near a dealer's premises in YEARS, yet I frequently manage to buy gear using the above process with no problems whatsoever, and usually end up totally satisfied with my purchases - that's WHY I don't need to box-swap!
    Look at my Gallery thread, and the amount of stuff I've been buying recently, from cartridges, stylii and SUTs, to speakers, cables, headphones and headphone amps - much of it from the other end of the world, and NONE of it was auditioned or chosen from specs! Just simply through thorough research, and ultimately having the balls to trust my instincts.
    Fortunately, all of it was a success, therefore I'll be owing and enjoying those items for many years. And I've adopted the same system-building process too, for YEARS, long before AoS was born, and made VERY few mistakes along the way. Every single part of both of my current systems was chosen using that methodology.
    Do you honestly think that's just pure luck?
  3. #153
    Mine tell me I'd be having a chat with Colin Wonfor if I had the dosh.
  4. #154
    Yeah, Colin's as sound as a pound - and an 'expert' who TRULY deserves the title, when so many don't!
  5. #155
    I haven't 'auditioned' anything, or been near a dealer's premises in YEARS, yet I frequently manage to buy gear using the above process with no problems whatsoever, and end up totally satisfied with my purchases - that's WHY I don't need to box-swap!
    Look at my Gallery thread, and the amount of stuff I've been buying recently, from cartridges, stylii and SUTs, to speakers, headphones and headphone amps - much of it from the other end of the world, and NONE of it was auditioned or chosen from specs! Just simply through thorough research, and ultimately having the balls to trust my instincts.
    I never said that. Obviously experience helps, likewise a decent budget to spend in the first place. If you buy equipment that has solid engineering chops behind it you're not likely to go far wrong. Whether you do that through experience and gut instinct or by studying form makes no difference to the outcome.
    I don't tend to put much, if any, faith in subjective reviews because I know - from experience - that personal taste and, to an extent, expectations, differ wildly.
    As far as this forum is concerned I know my personal taste in presentation differs substantially from the bulk of the membership. This, by extension, can be applied across the hobby as a whole. So I prefer to look at specs and measurements to decide if something is well-engineered and worth a punt, as opposed to just relying on the 'what someone thought when they listened to it' method.
    Shortlist so derived, I take a punt, then I have an extensive listen, usually with various combinations of other kit that I already have.
    It's not infallible but then neither is your method or you would still be settled with your old Naim/Spendor system.
  6. #156
    I'm Tony.
    Valves amps can rock really well *if you have the right ones* no question, just think what are the Marshal 4 x 40 cabs powered by?
    Coherent Systems
    Real high end sound with musicality not hifi
  7. #157
    I think you mean 4 x 12 ?
    Quote Originally Posted by Mr. C View Post
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
  8. #158
    Yes, but I've learned SO much since then, particularly about achieving the highest SPPV, and have stuck with largely the same system since - and that was 2009! How many systems or different bits of kit have you gone through in that time - and where are you now?
    And here's the thing.... In REAL terms, how much progress have you made?
    I know, beyond question, that if I were to return to my previous Naim/Spendor system, it would be a massive downgrade on what I've got now - and crucially - assembled at lower cost. Back in my Naim days, I was dropping £8k on the likes of a brand new NAC52 and Supercap PSU and not batting an eyelid, or £6k on a CDSII/XPSII.
    But I learned from my mistakes, and how to spend that money FAR more wisely!
    One of the telling tests for me, in terms of ascertaining if someone's on the right path or not, or if they really know what they're doing, easily facilitated if they're a friend you see regularly for example, is assessing whether the sound that they had going on, as it were, say 10 years ago is notably improved by the sound they've got going on now.
    Often, however, that isn't the case and its usually only different, or often worse, and so in real terms they've gone BACKWARDS more than forwards, and subsequently so has their bank balance, with all the swapping and changing!
    Quite simply, if you *really* know what you're doing and have good ears, then EVERY new system you own, or change of component, should effect a GENUINE no-brainer sonic improvement, acknowledged and heard by others listening to it, who also have good ears and had heard the sound that preceded it.
    THAT is how you move forward and make genuine progress, so if your system of 2020 doesn't sound markedly better than the one you had in 2010, despite being able to chuck the same amount of time and money at it, then unfortunately you've failed. That's the brutal truth. Now I'm not saying that applies to you, but judging by the evidence I see so often on forums, sadly it applies to countless others.
    And yes, no judgement criteria or approach is perfect, and that includes mine and yours, but at the end of the day for END USERS of gear, not builders or EEs, this *should* be a subjectivist hobby, and therefore ultimately our ears should always be the ones to decide, not what's contained in any text journals, Johnny's book on the laws of physics, or otherwise, or some erroneous quest for 'accuracy', as for me that road, for most, will ultimately lead to frustration and disappointment.
  9. #159
    Yes, but I've learned SO much since then, particularly about achieving the highest SPPV, and have stuck with largely the same system system since - and that was 2009! How many systems or different bits of kit have you gone through in that time - and where are you now?
    All the progress I needed to. I was done and dusted, had a superb sound, exactly what I'd been after all these years. Then the amp went faulty. Try finding another Krell KSA50S for sale in Europe. If you can I'll buy it. There's just not that many and the owners hang onto them like their balls.
    Also don't forget that I have the separate hobby of being into the equipment. I also buy kit just to see what it is like, or to revisit stuff I had years ago, or because I just like the looks of it.
    Your suggestion that it is only 'objectivists' who are chopping and changing all the time is well wide of the mark. I'd say they are less likely to go chasing rainbows myself. You may say that their systems are not that good but that's just one man's subjective opinion.
  10. #160
    I'm Tony.
    Sorry Tony
    I was getting all Ritchie Blackmore'd for a moment there mine starts at 11
    Have a few of those cabs kicking about Celeston drivers??? he had an extra driver stage giving around 270Watts from each cab I believe.
    You want to buy another KSA50 Martin? I have at least two that are serviceable easily put back to correct condition
    Coherent Systems
