Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 127
Thread: Grounding boxes?
    I'm Josie.
    Default Grounding boxes?
    Hi.
    Could anyone give me any idea if these voodoo-like boxes actually work?
    I ask because a friend of mine in Belgium has just bought some Entreq boxes and he says they really do make a positive difference. He's certainly not one to make stuff up, so... do they work?
    The more I look on the net about the 'grounding box' the more I'm intrigued.
    I do love my crystals and I do believe they can be used to comfort people. I have known this to be true.
    Entreq grounding boxes seem to be the the most famous manufacturer but other manufactures are now stepping in with positive results from users.
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
    I know some like them, but don't personally think I could post anything polite about the idea.
    I'm jamie.
    well if you think crystals can comfort people the grounding boxes should be right up your street.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Allen.
    I'm very sceptical about these boxes filled with what looks like charcoal with a piece of wire coming out of it
    And how much do they cost
    I'm Kevin.
    I think it is one of those things you have to try for yourself, and see if it makes any difference.
    Kevin
    Hmmmm, I remember fetching up this very topic years ago and as always we had those who believed and those that didn't. Like everything else in this hobby, use YOUR OWN ears .
    PRE
    I'm Phil.
    Wise advice
    Eric Bibb
    I'm BigBobJoylove.
    The price of the Entreq boxes is rather high, but they certainly work amazingly well, and with immediate apparency in A/B tests I’ve heard.
    There’s a lot to get sorted before that stage though, and it’s certainly a case of ‘money to burn’ stature.
    PRE
    I'm Dennis.
    I'm sure that this was discussed extensively on this forum a few months ago.
    The trouble with using your own ears is that we cannot remove placebo effects unless DB tests are involved.
