Results 11 to 20 of 24
Thread: Where do I start\upgrade online streamer
    I'm Laurie.
    Ps, I tried two Ethernet cables, melco and MeiCord, sounded radically different, melco soft and sweet, MeiCord leaner quicker more energy. If in doubt try on tv, people tend to believe their eyes.
    Yes I’ve thought the bell wire feeding house is rubbish, but signal we value is the one that comes after router, switch, and clock. Ie after the signal is potentially rebuilt in same way as a CD players error correction does. My dac has a five second buffer on Ethernet to aid signal.
    Vitus sia025, brinkman Bardot deck and nyquist dac,Boenicke w8se, Melco server, audiovalve sunilda phono, kondo Cables, lots of Stillpoints, Ess rack.
    Worldwide 40 million chickens, ducks, and geese die daily for the plate, savage and wasteful.
    I'm Tony.
    To be honest, I feel neither really get close what is happening with FBA, to me Qoboz has a odd way of reconstructing the PCM data like it's deliberately been polished and manipulated to sound very hifi and some of the remixed albums sound truly wrong, that said if you like to FM then it is a quantum leap above that for sure.
    Tidal never like it, again its like the use there own MQA (Music Quashing Algorithm) this translates to the Tidal sound which again for myself is not correct. I am not saying it is not a step up from FM or internet radio, it is no question. However for myself and a great a many of our customers the word 'contrived' is very apt
    I have four of the subscription services, but only use one on a regular basis usually when I am working on new designs for thoughtful sessions
    Spotify premium, no it's not the same detail level or resolution, however it remains more faithful to the original master than the others plus the remastered albums do not sound so phish as the other two I have mentioned. Just some thoughts
    Coherent Systems
    Real high end sound with musicality not hifi
    I'm Edward.
    I wonder if the perceived sound quality differences between the streaming services is partly due to the different ways they deal with normalisation? LUFS and true peak level and all that malarkey.
    I'm Tony.
    HI Edward
    I personally feel it is the digital PCM reconstruction algorithm that each company employs to pack/unpack the data stream at the tx and rx points is the key here.
    Currently I know of a couple of hard core stream heads (digital equivalent to vinyl nuts) who think nothing of dropping five figures just on the info-structure of the home network before it enters the streaming device. They firmly believe it makes a difference.
    Still feel streaming has quite a way to go before it can get close to FBA.
    Coherent Systems
    I'm Edward.
    Hi Tony
    That interesting. I had assumed that the streaming services did not muck around with the files they received from record companies other than normalisation (and possibly addition of Metadata). Do you have some further details on what they do? A link? Genuinely interested.
    As an experiment I'm going to try do a comparison between local files and equivalent streaming tracks. I'll skip any MQA stuff, just compare Redbook vs Redbook. I only have Tidal.
    Meantime hope you are well.
    E
    I'm Tony.
    Hi Edward
    I am well thank you if seriously busy!
    If everything was equal, then all of the streaming services would sound the same (at each frequency reproduction point), but they do not, like a lot of high end hifi equipment they all have a house sound. imho
    So far I have yet to hear anything that convinces me otherwise regarding FBA, Qoboz on the sample highest rate doesn't get close to a quality red-book file playback locally.
    Hint:- if you are using SSD via sata then you have a long way to go, but it still sounds better than any of the streaming services even with Ethernet regenerators, clocks extra power supplies and super routes and switches. Plus you are just renting music you do not own it
    However for discovering new music then yes unbeatable, but once you have found the those new artists, obtain the the files used to make those recordings then decide.
    I use Spotify maybe 15 hours a week, my critical listening are files only, my stored collection is up to 0.6 petabytes on a dual custom built server. However I do appreciate that most people will love the convenience of streaming. Luckily I have both convenience and sound quality.
    If you would like a demonstration on files Vs streaming from mild to wild no problem at all, have now found the 'lost 8dB' in the amplifiers so now sporting a solid 122dB noise floor.
    Coherent Systems
    I'm Peter.
    Quote Originally Posted by Mr. C View Post
    I run a music streaming service, though not on the tech side, and From my knowledge the files that the streaming services receive from the record companies are streamed as the files as received and stored. We don’t alter the files in any way.
    From a listening point of view I have spent a long time trying to get Qobuz to sound as good as my CD transport or files delivered from my hard drive. I have finally achieved this. The fact that you have not yet got there means One of two things: either your transport (from cd drive or hard drive) is better than my arrangement, or you Qobuz streaming set up is poorer. Difficult to know which but it would be interesting to find out.
    For me Qobuz comes via a Modem and router with a lps on the latter. Then to a Cisco switch via cat 8 cable. From there via Cat 8 to a SOtM network bridge with a separate clock from SOtM, both powered via an SOtM power supply. From here via a friend's bespoke USB cable (He is an electronic engineer who makes astonishingly good home made usb cables) to a Vitus DAC. This sounds as good as a CD played from the Vitus transport to the same DAC. But it took a lot of effort and messing about to get to that point.
    I'm Tony.
    Quote Originally Posted by Duckworp View Post
    Hello Peter
    Thank you for your reply always interesting to hear other peoples experiences regarding streaming.
    Let me run through a few items that maybe of interest for you:-
    For the streaming side of our set up the incoming Ethernet data side I have constructed the following set up:-
    A bespoke 4G mobile router (which just feeds the streamer only and is located very close to the streaming device), which I have made internal improvements and upgrades. This is fed by one of our ultra quiet QP-1 power supplies to a bespoke Ethernet re clocking device, which is also fed by a QP-1.
    These are sat on dedicated isolation devices, Ethernet cabling is by Crystal Absolute dream RJ45 0.75m cables (2 off) this enters the streaming device.
    Both RJ45 signal conditioner and re-clocking device are slaved via a Mutec Ref 10 SE-120 which I have further enhanced, cabling is our own BD range.
    All of these devices are connected via systems main grounding (0 volt) system. All of the incoming mains power has been treated via 28 point filtration system and runs our BD cabling on mains power before entering any mains powered device.
    The pcm audio data leaves the streaming device via AES67 (which is imho the best method of digital audio data transfer currently I believe) Yes I have worked with I2s over HDMI, currently working on a better RJ45 method, taking some time though I will get there!
    Having over 15 years of experience with high speed digital data systems (up to 40Gb/s data rates so but our experience is not just audio Peter) We also have two recording studios in our portfolio as well
    USB is absolutely not the way to pass audio data at it best possible integrity rate, it is not the data rate per say plenty there up to 480Mb/s usb II but the phase and latency errors that are indicative of the USB II methodology). USB is used as there are so many usb devices in the world today, companies would daft not to fit it) However make no mistake not the most idea method of digital audio data transmission.This is why so many usb helping devices are available on the market at the moment. YMMV.
    This then feeds a Mutec MC3+usb re-clocking device (digital audio signals this time) again powered by a QP-1 power supply, Again this is slaved via the Ref 10 SE-120 master clock with a phase noise of -120dbc @1hz dropping to -172dbc @100Khz, So basically the 10Mhz reference word clock is rather good. Then the AES67 audio output to the TAD dac.
    So the incoming Ethernet signal is as clean and quiet as I can make it currently and is totally separate and isolated from any other internet traffic in the building, it is purely used streamer control and incoming streaming audio data only.
    I am not saying you can't obtain a good sound form Qoboz et al and I have heard it match a reasonable CD player once or twice now, but I am talking locally stored files only. Not supplied via wifi or a NAS drive, but on board isolated drives.
    This is my experience thus far with streaming services has been so,so. Always happy to introduced to new ways no problem at all.
    Just a thought for you, streaming has to be transmitted from point a to point b could be many 100's or 1000's of miles between these points or maybe 5?. The infrastructure between these points is not 100% loss less, BEFORE it gets to the router, then we have all the issues there after (not saying these cannot be addressed however) but at each stage errors will happen, hence why you box 'x' or cable 'y' to counter act them
    A quality streamer I (not expensive), with isolated ssd drives with ultra short circuit pathways, minimal transmission lines with equal master files at what ever sample rate with have less distance to travel, incur less electrical and mechanical disturbances and require less hardware to deliver superior SQ.
    Especially now with the the new PCIe express methodology coming into play we are talking AI levels of data transfer via the new lane transfer protocols. So very large data transfer rates over ultra short distances with little more than very low nv ripple noise and much lower power consumption it is exciting times we are now living in!
    A side note here we have a fiber optical 300Meg pipeline available, what ever I do it just doesn't sound as good as the mobile router.
    Now getting the files, now that's another story!
    Coherent Systems
    I'm Peter.
    Wow, your system sounds v.complex. So with both of our systems we are getting Qobuz to sound as good as CD. In my system the CD transport and DAC are in one unit, the Vitus SCD025. This same DAC is accessed via a USB input from the SOtM bridge. Despite all the issues you mention (the hundreds of miles of cable, the inherent problems of USB, the noise generated by routers, bridges, power supplies etc) the fact that this 'damaged' file is sounding as good for me and you as the one generated from the silver disc in the same box as the DAC is nothing short of extraordinary.
    What I think you are therefore saying is that, ignoring streaming services now, there is then a further leap in SQ when you move from a CD transport to a locally stored file. I source my files from a hard drive attached to an NUC dedicated roon core (a roon nucleus in all but name). This then supplies the files to my Cisco switch and from there via 10m of Cat 8 to my Hi-Fi room to the SOtM bridge with its external clock, then via short USB to the DAC. The SQ from these files is identical to CD and Qobuz. You are saying, I think, that the SQ of this should be better. I have tried attaching the hard drive directly to the SOtM but it sounds the same. What are you doing to make a local file sound better than a CD, through the same DAC obs?
    I'm Tony.
    Good Morning Peter,
    Thank you for your reply.
    This performance availability has been around for a long time. correct copied CD files *will always sound better than the originals* providing you keep the signal pathway clean and use a suitable so called bit perfect software facility. Respectable equipment and a good clean mains supply.
    If we take CD in basic form we are shinning a light on a spinning disc and using the reflections to extract the optical information as binary digital data then convert the optical to electrical use a Reed Salomon error correction code to iron out this mis reads of the pits and lands of the disc.
    Yes better transport mechanisms, clocking circuitry, power supplies and memory players all improve things no end. However you cannot get away from the fact you a shinning a light on a spinning disc each time. In the same way with vinyl you are dragging a rock around a piece of plastic and all that entails.
    Once you have extracted the data from the CD or obtained a master file red-book copy or greater resolution item and store this on SSD locally, each time you playback a file you have the digital data already in its format available without having to convert light to electrical each time you listen.
    Personally I have not been listening to CD for close to 15 years, we demonstrate CD's regularly and on certain equipment they can sound rather good.
    Not doing anything different with the files Peter I promise!
    Think of data transfer from the point of source some 12m's away and how much connectivity it goes through. When you connected your hard drive
    to the SotM unit was it via USB or RJ45? was the HDD powered via wall wart or quality LPS? Was it on the same supply that power your digital front end?
    I could show you how much internal (and external) electrical noise a SoTM unit makes (and many other manufacturers ) on our test equipment suite we have here and how this impacts all SQ along with other issues you would need to address.
    Part of our company profile we design high end audio digital electronics and streaming devices for other manufacturers so we have good grounding in digital audio playback abilities.
    If you would like to hear what is REALLY possible from digital playback then do get in contact and we will happily take the time to show and explain to you no problem.
    Regards
    Tony
    Coherent Systems
