Results 1 to 10 of 14
Thread: *Help me diagnose this flatulent bass driver
    I'm Graham.
    Default *Help me diagnose this flatulent bass driver
    Looking for some help on diagnosing this problem, on a Rogers LS2.
    The first few seconds is a subsonic tone then I switch to a frequency sweep.
    https://1drv.ms/v/s!AvReE5AaGPrehNNddC_fVKOXgWF0OA
    In normal playing it sounds pretty decent and its*not immediately apparent something is wrong.
    The other speaker doesn't exhibit any of this*vibration when playing the same tracks.
    I can't detect any obvious air leak around the driver enclosure or cone but that isn't to say there isn't one*😉
    Any advice much appreciated.*
    Many thanks
    Graham
    I'm Sajid.
    Have u tried different amp and checked your connections
    I'm Graham.
    Yes good suggestion sajid, and i have swapped speakers over and used in entirely different system but unfortunately the problem persists.
    Not sure what we're supposed to be listening for.
    I'm Graham.
    Hi wal,
    The other speaker doesnt make the same vibrations/chattering sound when playing the same low frequencies
    I have made a recording of the good speaker using the same tracks. However if you play on a phone you may not hear anything as the freq will be too low to replay.
    https://1drv.ms/v/s!AvReE5AaGPrehNRCvpJrL01uXBccFA
    Many thanks
    Graham
    I'm Sajid.
    Hi did u look at the speaker mountings ... and if they fine then it be the crossover
    I'm Graham.
    Ah interesting, was assuming it was a problem with the driver.
    I was planning to swap the driver over so hopefully this will isolate it to the driver or crossover.
    I will swap the drivers when I get the time.
    I'm Dennis.
    Put the speaker in question on the other amp channel to eliminate the amp.
    Try gently moving the cone by hand with a very gentle bias towards the periphery around all 360 degrees to reveal any rubbing.
    Use a sine sweep to reveal any loose parts on the cone/motor assembly.
    Dennis is right. It's likely to be the voicecoil fouling in the magnet gap. The crossover is less likely to be the problem.
    There are ways to deal with this, but you need to know what you're doing. Otherwise, a replacement driver is required, and they should be replaced in pairs.
    Actually I've solved this problem with two pairs of speakers in the past. The two probable reasons for this are that the coil has overheated and bubbled the varnish watch is now rubbing, or (less likely unless the driver has been opened) a small foreign object has got in the voice coil gap.
    If you do the test above to confirm that there is some rubbing, then give it a minute of pushing on and out so the coil is gently rubbing and you rub a bit of the varnish off (or dislodge/rub away the foreign object). Try the speaker again, if not solved, repeat. You could try rubbing a bit harder this time but bear in mind it will increase the risk of damage to the voice coil. Patience is the watchword here.
    There's a risk of damage to the voice coil but if you're going to replace it anyway there's no harm done.
    Sent from my HRY-LX1 using Tapatalk
