I'm Allen.
I'm Charlie.
The A820 was nearly £50k back in 1986, when it was released - that's over £250k by todays standards. This one has been looked after, is ultra low mileage and is priced firm.
R2R: Studer A820 1/2 inch 2 track; Otari MTR-12 1/4 inch 2 track; Sony APR 5003; Sony APR 5002; Studer A807/II. Vinyl: Platine Verdier Allaerts MC1B/Schroeder Reference & Model 2 Decca C4E/Hadcock 228 TRON Seven Reference phono. Keith Monks MkII RCM Other analogue source: Nakamichi Dragon with ANT4066 mods. Amplification: TRON Meteor preamp TRON Voyager 20B SET power. Speakers: Avantgarde Duo. Digital: computing at last with Prism Sound Lyra 2 A2D converter
No implications about this particular machine, but generally, if there is so much value in low usage, as indicated by the analogue counter shown, isn't there an incentive to "clock" them like Arthur Daley used car salesman types did with cars years ago? Can they really be regarded as an infallible measure of hours used?
Sent from my HRY-LX1 using Tapatalk
I think you would have to dismantle the counter and re-assemble to show a lower reading. Some equipment (not necessarily Studer) is fitted with an electro-chemical lapsed time recorder. I don't think these can be 'reversed'.
https://docs.rs-online.com/b953/0900766b8001a8fe.pdf
(I've just noticed that the above can be reversed, but it would take as long to do it as the difference in hours required.)
I also think you can tell by the head and guides wear on the usage if its been clocked
What did they replace the SAL capacitors with? Its hard to find a better alternative even now ?
Alan
