Results 1 to 10 of 18
Thread: Optical cleaner for vinyl
    I'm loheswaran.
    Default Optical cleaner for vinyl
    Dear all
    Has anyone tried a non alcoholic optical cleaner on their vinyl? A very good cartridge retipper said to use it do clean your stylus - so why not use it on your records?
    Fyi anti reflective coating are often very delicate Nd they draw oil towards them - hence my logic
    Thanks
    I'm Allen.
    I don't need to clean my styli as I only use cleaned records
    Would not use any fluid type cleaners , NO WAY
    I'm loheswaran.
    Dear Audio Al
    You have clearly mis-understood my question, hence you giving an answer to a wholly different question. Ie not what do you use to clean your stylus
    My question was not if i should use a liquid cleaner on my stylus - nor indeed the state of your records - and that all your vinyl is so pristine that you never have to clean your stylus.
    I was trying elicit a response by anybody who had tried a non-alcoholic optical cleaner on a record.
    FYI the cartridge tipper does happen to know his stuff.
    I'm Gary.
    What are you Sellin’?
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm loheswaran.
    Nothing - audio ain't a place to make money...
    I was thinking of experimenting with some optical cleaner on some records - have you tried it?
    So how were your records cleaned?
    I'm Allen.
    1st they go in the ultrasonice RCM one time only , Then I use my Loricraft PRC4 and allways use a new vinyl sleeve
    I'm guy.
    I would have thought it would work out quite an expensive way to clean records?
    Anyway, I thought that I would look them up and found this strange claim:
    https://www.zeiss.com/vision-care/in...ing-wipes.html
    The alconol free cleaning wipes contain Propanol and Ethanol according to the Zeiss data sheet
    LP12, Ittok (black), DV10X5, NVA Phono 2 (twin supply), NVAP50, Art Audio Quintet 15w power amp, NVA LS5 cable, Rega Ela mk1's.
    Sony CDP XB930.
    I'm Angus.
    No alcohol in the Display Cleaning Wipes, alcohol in the Lens Cleaning Wipes.
    Both use fluid don't they
