ARC (Audio Reproduction Company) 050 - Passive/Active 2-way speakers
These dynamic little things will be instantly familiar to anybody who owned Nytech kit. A German company, Nero, came up with a revival model in 2015 (?), priced at four figures, methinks.
One can use them in straight passive mode or pop out the crossover, add an electronic crossover and go active.
Anyway these are completely original versions, all four drive units are full functional. They also come with their original crossovers for passive operation, unchanged from the original except for the addition of proper 4mm binding posts. NERO also sells a new, updated version, if you feel like experimenting.
Cabinets are worn, as can be seen in pix.
Still, don't think you'll do much better at just £75 collected from Bedford. Drive units alone will be worth more than that...
DSC06810 by Brer Rabbit, on Flickr
DSC06811 by Brer Rabbit, on Flickr
DSC06812 by Brer Rabbit, on Flickr
DSC06814 by Brer Rabbit, on Flickr
DSC06815 by Brer Rabbit, on Flickr
DSC06818 by Brer Rabbit, on Flickr
DSC06819 by Brer Rabbit, on Flickr
DSC06820 by Brer Rabbit, on Flickr
DSC06822 by Brer Rabbit, on Flickr
DSC06823 by Brer Rabbit, on Flickr
- You may not post replies
- You may not edit your posts
Forum Rules
