Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Photo hosting site
    Default Photo hosting site
    Hi, can anyone recommend a photo hosting site,a free one I used to be able to upload my pics from my tablets internal files onto here but it no longer works, I now just get an error message, thanks
    This is what you want, James. FREE and piss-easy to use: https://postimages.org/
    Bobby dazzler, thank you edit, that didn't work I'm afraid, entered my email and the password provided and diddly when I try to upload from my files on the tablet i get, theartofsound.net says, the following errors occurred, 20200531_165420.jpg: upload of file failed, any ideas?
    I'm Phil.
    Flikr is brilliant
    Eric Bibb
    Can anyone help James with his issue? Grant or Geoff, you're normally good with this stuff
    The site works perfectly well for me, so I've no idea what the issue is.
    I'm Ben.
    https://imgur.com/ is really easy. When you upload a photo you want to host, copy the BBCode (message boards & forums) and paste it into your thread or post.
    I'm guy.
    I signed up to "Postimage" only a couple of days ago. First time that I have used any sort of photo host and it went really well. Bearing that in mind these are the things that I did (I am not an expert, so please excuse any overly simplistic bits!):
    three option boxes (after email and password set) to:
    "default"
    "640x480" (for message boards). - I have a hunch that this may be the key one
    "no expiration"
    Then "choose image"
    you are then given 8 options, I tried a few and this one suited me:
    "hotlink for forums" url... gobbledegook.........
    It "tells me" that photo is copied
    then paste in to post:
    et voila
    LP12, Ittok (black), DV10X5, NVA Phono 2 (twin supply), NVAP50, Art Audio Quintet 15w power amp, NVA LS5 cable, Rega Ela mk1's.
    Sony CDP XB930.
    Yup, I just used it to post the image above! No issues whatsoever
    Method:
    1) Select 640 x 480 (for message boards) from the dropdown menu.
    2) Click 'Choose Images', which should take you straight to all the images stored on your computer.
    3) Click on the Image you want to upload.
    4) Then on the next menu, look at 'Hotlink for Forums' on the left, copy all the data therein.
    5) Then paste the data to the posting box on AoS, then post the pic on whatever thread you wish - job done!
    I'm Nick.
    What is the error message you get?
    Nick
    My system...
    Follow AOS on Twitter: @AoS_Forum
    For Imgur, here's a brief guide I wrote a while back.
    (I used Imgur to post it )
