Results 1 to 9 of 9
Thread: FS Leema Tucana Intergrated Amp
    I'm Shaun.
    Default FS Leema Tucana Intergrated Amp
    Due to accumulating too much equipment my second system is up for sale
    This is for my Leema Tucana Mk1 Integrated Amp in unmarked condition - well I cant see one
    Audio Specifications
    Power Output: 8 ohms: 148 Watts RMS per channel, 4 ohms: 285 Watts RMS per channel
    Minimum load impedance: 2 ohms.
    Output Current: greater than +/- 50 Amps
    Frequency response +0/-3dB @ 1W: 5Hz - 80KHz
    Noise (A weighted, volume control minimum): -100dBm
    Signal to Noise ratio (A weighted, ref: 285 Watts RMS 4 ohms): -104dB
    THD (10 Watts RMS 4 ohms, 1KHz): 0.004%
    THD (Max output before clipping, 4 ohms, 1KHz): 0.004%
    Maximum DC offset: +/- 15mV
    Sensitivity for maximum output (CD input): 565mV RMS
    Sensitivity for maximum output (other inputs): 311mV RMS
    Output Impedance: 0.057 ohms Damping Factor (8 ohms): 140
    This is a fantastic amp and retailed at over £3000 and is built like a beautiful tank
    I am after £1050 plus postage for it - The MK2's command over £2000 used and the difference is minimalIMG_2132 by S ONEILL, on Flickrhttp://IMG_2135 - Copy by S ONEILL, on Flickrhttp://IMG_2137 by S ONEILL, on FlickrIMG_2134 by S ONEILL, on Flickrhttp://IMG_2136 by S ONEILL, on Flickr
    striking and attractive amp..
    I'm Shaun.
    Thank you
    And I managed to get pictures on pretty easily this time :-)
    Quote Originally Posted by oneills View Post
    Thank you
    You did a good job and showed the rear connections, which often get missed.
    I'm Peter.
    A fine looking amp, and apparently it sounds as good as it looks... I was tempted to go down that route recently, but ended up upgrading the phono source instead...
    GLWS
    Sent using Tapatalk
    Pete
    Musical Fidelity MX-VYNL
    Musical Fidelity X-A200R
    ATC scm11
    Excellent, now the buyer won't be saddled with the task of taking a rear pic and posting it on here as soon as they get the amp home.
    Sent from my HRY-LX1 using Tapatalk
    I'm Shaun.
    Bump for the week end - and I should have put ONO on this
    Just what you need is a new amp blasting out your favourite tunes when you come home from the pub
    I'm Shaun.
    Just had it confirmed from Leema that this is a late Mk1 built in Oct 2008
    I'm Shaun.
    Now SOLD STP
