Results 1 to 10 of 13
Thread: issue with sme 3009/Thorens TD160
    I'm Phil.
    Default issue with sme 3009/Thorens TD160
    Hi all,
    I have just got round to fitting a SME 3009 on my Thorens, all looked good until i realised that it didn't fit within my plinth and requires more space at the bottom...
    Is there any solution to this other than cutting a hole in the baseboard and adding extra long feet?
    Thanks
    Phil
    Leave the base off, it'll sound better that way. Yes, use taller feet and investigate side entry cables.
    I'm Phil.
    Thanks, Geoff. Does anyone know where i would be able to get a right angled/side entry connector cable?
    Get a new plinth the original Thorens plinths have always been the weak part or the TT, get a new heavier plinth and baseboard
    I'm Phil.
    I already have a new plinth, but it is the same height as the original.
    you can alter the sme for rca's that go in sideways. that will solve it too.. usually kits on the bay
    SME developed the side-entry version for the Belling & Lee 5-way connector in the '70, so their arms would fit in the shallow plinths of the Thorens 125, 150 and 160 TTs as well as those of the ERA Mk.6 turntable. The SME arms with this modification are designated "/SE".
    I would replace the vertical entry Belling & Lee socket with side entry RCA phono sockets. Conversion kits are readily available, and it would give you the option to try different cables.
    Ah - I see Grant has just referenced a suitable coversion kit.
    I'm phil.
    The new plinth should be made deeper out of better timber with a much denser base board,like 12mm MDF. that’s the point in getting a new plinth made.
    Modded td160 super Thorens ol encounter arm hana sl cart, angle audio studio pro mc virtual battery phono amp with separate psi, Onix pre and mono amps, Onix CD player, Onix BWD and soap tuner. B&W dm2 speakers or super pencil 12 speakers, atlas cables, seperate mains power supply with earth spike.
