Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: Differential in sound quality between turntable and digital - Old Linn system
    Hum , now that takes some thinking about very unusual for a well set up vinyl system to be that bad
    I agree, and wonder if the problem is elsewhere - can you not borrow a phono stage (doesn't have to be expensive), and try it into one of the line level inputs? I'm assuming your amp has it's own phono input.
    We all know that built in phono stages are crap even on quite expensive amps, so as others have said trying a separate phono stage would be your 1st point of call, other things to check are the cartridge alignment and VTF and make sure the stylus is clean and not covered in crud
    True, I used to have a Musical Fidelity amp, and the phono stage was pretty grim, although the amp cost four times that of the preceding Cyrus 1. I think sometimes the phono stage on amps of a certain age was just a bit of an afterthought.
    Mike, while you're on here, are you up for receiving a visit this afternoon? I seem to have lost your mobile number
    Not always though. The phono stage in my Forte Model 2 pre-amp was great and the one in my VTL Deluxe is bloomin' amazing .
    I'm Brian.
    Default Differential in sound quality between turntable and digital - Old Linn system
    Thanks folks. I’m using an old Linn Majik1 integrated amp (but only as a preamp as I’m using two activ LK100s) . I might investigate another phono stage. I might also look at a ‘proper’ preamp of a similar vintage, ie a Wakonda or indeed Kairn. I will stress my hearing is not great with h/f being quite problematic! I also tried two different pressings of the same lp. The 2018 remaster was a bit better than the original 1980 pressing. It’s a brand new cartridge/stylus so I can rule that out, but I will recalibrate it with a protractor.
    I'm Kevin.
    A better stylus would probably help as well. Rather than the elliptical nude, something like the ML or SH would give you more detail.
    Kevin
    Quote Originally Posted by BDD View Post
    Not to worry, most of us on here are deaf as a post. With the exception of Marco, he has ears like a bat. Looks like one too. I probably should have whispered that last bit
    I'm Brian.
    I'm Brian.
    Thanks - I’ll look at that further
    Quote Originally Posted by graham67 View Post
    And unlike digital which rewards some initial investment but quickly hits a ceiling
    Well my digital system has no ceiling.
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
