Results 21 to 30 of 34
Thread: Best valve amp for Tannoy 15" DCs (up to £3k?)
  1. #21
    I'm John.
    OK, after asking the question here and elsewhere, and accepting that I can't possibly hear all contenders (especially these days) I decided that I'd go on consensus and similarity to what I've currently got, and have ordered a Radford Revival STA25 mark 5. I've heard nothing but good things about these amps, it will be easily able to drive the Tannoys, and it's within budget (and seemingly built to an extremely high standard).
  2. #22
    Quote Originally Posted by oktapod View Post
    Wise choice
  3. #23
    Wise choice
    +1
    Sent from my ONEPLUS A5000 using Tapatalk
  4. #24
    I'm Paul.
    PYE HF12's run my bespoke Tannoy 15's... Basically the same as the PF91's and my friend has HF25's on his Windsor's... I will not go into the superlatives....
    EMT 930ST
    Garrard 301/3009 MK1
    Micro Seiki MR-711/MA-202L
    Stax SRA-3S MM phono amplifier
    Nagra BPSv2 phonostage
    BigBottle BB3 Phonostage
    Telefunken Bv.42-01 Transformer
    Hashimoto HM-3 Transformer
    Braun CC4 Transformer
    Ortofon Spu Synergy
    Ortofon Cadenza Bronze
    Miyajima Waza
    Denon 103SA
    Audio Technica AT33 Mono
    IFI Pro Linestage
    PYE HF12 KT66 Monoblocks
    Uchida Sun Audio SV-300BE
    Crimson Elektrik CS1500
    Quantum Electronics 202D
    Marantz 1060 Integrated
    Western Electric Line Transformer
    Yamaha CDR-HD1500
    Tannoy 15" Bespoke
  5. #25
    Lots of threads on here about this...A Radford would be really nice, as another option I had a Art Audio KT88 which was a nice match-they used to do a mono block version with two pairs of KT88 which would be even better...
  6. #26
    I'm sorted.
    Luxman does it all, literally with knobs on.
    Bit late to the party but +1 for a Luxman, I use an L-509X with my Legacy Ardens & it's the most lucid sound I've heard (bit more than your budget though).
  7. #27
    I'm Phil.
    mmm thats good to know , must bear that in mind for the future
    Eric Bibb
  8. #28
    I'm Andy.
    I have used a few different valve amps on my Tannoys from Flea Power 1.8w Decware which were lovely in the mids and highs but were lacking in the lower regions, Ok if all you played was female singer songwriter type stuff. I used a Glasshouse 300B for quite a few years which was a definite improvement in the lower regions but still not enough. Current amp is a Bel Canto Set 40 using 845 valves and outputting about 38 watts. This amp is by far and away the best sound I have had out of my Tannoys. All these amps are single ended, I have not tried a push pull but would expect further low down improvements but maybe at the loss of the beautiful mids and highs. Its quite clear that the K series version of the Tannoy 15"DC drivers do like a few watts up them.
    Analogue
    401 / PU7 / AT33ev
    Digital
    Innuos Zen Mini Mk 3
    Topping D50s
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
  9. #29
    Then the PrimaLuna Dialogue Premium HP or the Newer Evo 400 with 70wpc into 8ohms should suit it nicely
  10. #30
    There's a lovely KT90 valve amp in the classifieds that will work well!
