Make sure you buy an original Thorens belt. I've had two TD150's and I now own a TD160. Clean the inside of the platter is a good move. My current TD160 had a horrid black ring on the inner platter. Cleaning with meths improved speed stability by 0.1rpm, not much but I'm quite sensitive to pitch stability and I could tell. The biggest improvement came from belt replacement. Thakker belts are quite good and improve on platter speed stability I've noted bewteen a 0.1 to 0.3rpm improvement in platter stability in the three examples I've owned. The best belts IMHO are original Thorens and these seem to be the best for speed stability improvements. You may also want to get a cheap laser tachometer from ebay, you can get them now for <£30 with the ability to track speed stability to two decimal points, or failing that an app on your phone. Timing things with a stop watch isn't that accurate.
