i used the isotek ultimate setup disk , it was simply the best way for me ,
peter
peter
I'm William.
Hi All
I quite like this guys explanation. Setting your speakers starts round about 18:00.
https://youtu.be/84Pf0ycbyBM
Happy New Year to all
Regards
William
Hmm, so tweeters radiate like lasers do they?
It would be rather unusual if they did. Talk about a narrow sweet spot!
Admittedly ribbons and electrostats can have a comparatively narrow dispersion, but hardly what one would call 'like a laser'.
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
The higher the frequency the more directional it is.
Well worth a read;
https://faculty.tru.ca/rtaylor/publi...ctgeometry.pdf
Thanks for this link, Frank.
I have employed a similar approach to toe-in, as the author discusses, in my listening room because the area is a little smaller than the ideal for minimisation of reflections at the listening position.
The results have been worthwhile.
I did note, however, that the article does not consider wave interference due to increased toe-in and it's effects, such as comb filtering.
No doubt for reasons of simplicity, it does not include dispersion angles or frequency in the equations.
Neither does it discuss the relationship between height of the listening position and bandpassed drivers. Or ceilings!
Nonetheless, It's an enjoyable academic article.
Johnny Dodgem.
Cartridges vintage MMs including Pickering xsv-4000/xsv-3000 : Stanton 881s/D81 : AT140LC/VMN40ML
Spinners hot rod 1210 (Jelco 750D, Origami, Ammonite, Longdog, Vantage, Achromats) : Pye G63 & Garrard AT6 : Two full custom Lencos : Kenwood KD-650D
Streaming Qobuz : BluOS & Node2 (Fidelity Audio modified) : RME ADI-2 DAC
Pre-amps Tron Seven (GT modified) : Conrad Johnson EV1 : Croft Micro 25 : Decware ZStage
Power Amps PrimaLuna ProLogue 5 (KT120) : PrimaLuna ProLogue 4 (KT77)
Speakers The Edingdale : Meadowlark Hot Rod Shearwater
I'm guy.
Thanks for the link - I usually give up part way through but he seems to be knowledgable, interesting and (most importantly!) not trying to sell me anything
Link has got me thinking, I would like to see opinion/s on long large rooms and carpet or not - will start a thread.
LP12, Ittok (black), DV10X5, NVA Phono 2 (twin supply), NVAP50, Art Audio Quintet 15w power amp, NVA LS5 cable, Rega Ela mk1's.
Sony CDP XB930.
He probably didn't include the ceiling as the height puts the first reflection delay outside the 'danger' window.
I'm intrigued why you think toeing in increases comb filtering/wave interference can you point me to any links that discus this?
I may be misunderstanding here-wouldn't be the first time;-);The height vs bandpassed drivers I can only conclude the author is assuming any listening is made at a distance sufficient for the main front lobe to form?
Cheers
F
I think you're correct in both postulations.
That is, the author is assuming a front lobe at the listening position and that ceilings are considered not dangerous in this scenario.
Perhaps, this is one case in which an artexed ceiling may be an improvement over a flat surface! Gotta break up those reflections, man.
I think it's a good article - I was just noting the assumptions required to keep the maths 'doable' - for example, the thickness and effective density of the surfaces is ignored, et cetera.
I don't have any links to comb filtering in domestic audio systems but I think it's safe to say that toe-in angle is a factor in HF interrelation.
I'm happily prepared to be shown otherwise, if I'm scribbling nonsense.
(The lower frequencies are part of the equation also but if you are listening a few metres from the source, then room interaction is probably of greater consequence. Your neighbours may disagree, given that the wavelength of 80Hz is approximately 4m, whereas 8000Hz is about 4cm.
I've experienced comb filtering in the bass when operating PA systems in the open air, with multiple driver arrays, at listening distances that are significant with respect to wavelength.)
Consider two cabinets in parallel. At a distance x from the tweeter, dependent upon the horizontal dispersion, the direct waveform from each source will meet and interact.
If you increase toe-in, then the wave fronts will meet earlier. If they meet in front of the listening position, then there is the potential for this effect to be heard.
Would you agree? I know that there's not much pressure energy involved but perhaps enough interference to change perception of the stereo image, if not timbre, which is where the author of the article comes in.
